Say i have a forged motor for argument sake a rb26.The motor has a full forged bottom end crank rods pistons and so on.
The kit is pulled out of the block and not marked,
So piston/gudgeon pin/rod are not marked where they came from.Even the rings are in a pile....
Any one offer some insight if this can go back together saftly
Is that a massive head #$%^ and if they don t go back together the correct way is it catasrophic failure time?
Any one shed some light on this as im not a mechanic.
As much detail as possible please.
Edited by Gtir-keiron
Its been running,Pulled apart
My mechanic told me that the gudeion pins have to go back where they come in the same way they came out. from also the pistons have to go back on the rods they came from and so on and so on.
I was planning on doing new rings and bearings but i wanted to know about the other stuff.
My mechanic is anal......Things have to be perfect.. in his world of putting motors together.
just wanted a performance opinon.
Your mechanic is a guy who is trying to pose as someone who knows what he is doing.
Linish pins, resize and balance conrods as well as balance pistons and it doesnt matter what is what. As when they are balanced the piston and pin are matched to avoid taking too much off the piston. If you had a light piston and pin matched together you would have to grind excessive material off all the other pistons to get them to match up.
Someone who suggests putting an engine together without doing this clearly has no idea. Id say you grab your gear and go elsewhere mate.
A quick look at the early failure poll thread will show that there are a lot of guys who take on RB's without the experience with the poor customer footing the bill. Ive screwed together quite a few engines in my time but when i opted for a big dollar bill i went to the experts so the job was done right.
Edited by Supa Steve
Oh thats not what im saying.
Im saying he wants to know what gudeon pin came out of what piston and what rods it was connected to and what order the pistons were in.
Like i said hes anal about things when it comes to building motors.Hes a very good mechanic with alot of exp with RB Sr and nissan engines but sometimes i feel hes over the top and i don t want to spend money where i don t need too.
he already said i would have to replace the rings and bearing and i new that from the start.
Thats why im asking what my options are.
If i can get it all balanced and set up to as new or better then it should not be a problem yes?
thats why i wanted detailed infomation so i had options rather then him telling me i need to replace pistons and pins and things like that.
i think you may have missed it so i will put it a bit more direct.
it means 3/5th's of f*ck all where what came from except for the rod caps which are generally numbered and anyone who tries to tell you otherwise is giving you incorrect information. Clean everything up and weight-match to ensure best clearance and minimum grinding of pistons. Rods NEED to be resized and balanced to ensure they are exact. If he is as pedantic as you state then this should be a given for him to understand. Pistons and pins will only need replacing if the pin has flogged out the bore of the pistons and/or bent the pins.
properly prepped and assembled serviceable parts will have your engine as good as new.
best of luck
As steve said, everything can be measured to confirm where it goes, however if there is no discernable difference when measuring, then it doesnt matter where they go. Then check balance and assemble.
    • +27605538865 Powerful Lost love spells caster by Mama to work in 24hrs with Strong magic and Psychic Reading Skills. Do you miss your lover and want him /her to come back to you? Do you want your ex to be in a relationship with you again? If you miss your partner/soulmate and cannot think of living this life without them, then perform this fast spell will help you make your lover come back to you. Imagine a love spell that could bring back your Ex, return a lost lover, or fix a broken relationship. The love spells were created to restore the romance and strength of deep love while erasing the heartache and pain of the past. By restoring these emotions with a clean foundation, my witchcraft rituals offer hope to those who fear resentment and deep anger from a lost partner. specializing in lost Love Spells, Marriage Spells, Protection Spells, Spiritual Healing, Fortune Teller Many people still question whether love spells work or not, permanent or effective? This can be based from past experiences where they tried some spell casters but not fully satisfied with their results or the love spells worked for just a short period and sometimes even never saw any results. To avoid such situations you have to be careful with spell casters you approach, some are limited with certain Spiritual powers to cast good love spells to help people in their relationships Customized Love Spells This love spell is customized and suitable for bringing the one you love to you. If you are not with the one you love for any reason, we can cast this love spell to shock and manipulate the one you love into coming to you. This spell unites lovers, which includes reuniting lovers.+27605538865 Mama Naledi
    • +27737053600 Revenge spells and Death spells to punish someone until you are fully avenged By Mama Shamie Revenge spells to teach someone a lesson they will never forget using voodoo revenge spells. My spells of revenge will inflict serious harm on your enemies, so do not use my revenge spells unless you are sure. Revenge spells for cheaters & your enemies. Revenge spells and curses to help you get the ultimate revenge. Voodoo revenge spells for cheaters, ex lovers, your enemies & people who want to harm you. Give life for life, eye for eye, tooth for tooth, hand for hand, foot for foot & to punish your enemies with revenge curses & spells for revenge. If someone has truly wronged you and you want to get back on them with the ultimate revenge spell, then try this witchcraft death revenge spells. The most precious asset we have is life so the death revenge spell is by far the most powerful revenge spell in the world as it will lead to the death. I only cast the death revenge spell when you have given me all the proof that the person you want to cast upon deserves death as punishment. Spells for revenge to cause your enemy to have sleepless nights & frightening dreams. Banish bad dreams & nightmares if someone has cast bad dreams revenge spells. Call or Whatsapp me on *+27737053600*
    • Spell to Stop Divorce in your marriage +27605538865 Stop Separation with my Spell to stop Divorce Lost love spells caster The forces involved in this witchcraft spell can reestablish the loving bond between you and help to build a sturdy, loving relationship from which to start anew. Despite any previous hardships or issues, the spell work will reestablish the strong bonds of friendship and love upon that the wedding and relationship originated. Have faith, these rituals are very powerful and can reconnect you and your partner during a strong and harmonious relationship. If you think that your partner is considering either separation or divorce, use this magic spell to stop the forces that are calling it quits your relationship. It is very necessary that you act with haste since prolonged negative energies create difficulties for the efficiency of this spell. If your partner has already breached the subject of either separation or divorce, use the spell immediately to rekindle the love that’s the idea for your marriage or relationship. Stop a Divorce or Separation
    • Court Cases and Legal magic spells +27737053600 Win a Case Spell Mama Shamie People are accused of things they never do and others did they but need a retreat, with my Court Case Spells, you can win any kind of case whether you are guilty or not, are very effective magic spells; Court Case spells are used to solve any type of court case or legal matter problems. If you are suffering and tired and the case or any legal matter that you are going through is not ending then you may contact me for a very strong court case spells. and you overcome it. If you having problems in winning Court Case then you may try casting this spell and it will surely give you positive results. Court cases magic spells are designed to rescue you from search legal accusations in a very convincing way. Black Magic Court Case Spell ✝2️⃣7️⃣7️⃣3️⃣7️⃣0️⃣5️⃣3️⃣6️⃣0️⃣0️⃣ Black magic court case is very powerful magic spell specifically cast with black magic features to generate more magic energies to relive you off the hook from being convicted no matter whether you are guilty or not, the spell has enough power to make your case either dismissed or ruled in your favor. The power of magic can play tricks with the evidences with the aim of disappearing some of them which would have lead to your conviction; there is no limit to where the spell can end until the target is reached. +27737053600 Mama Shamie
