Gtir-keiron Posted September 25, 2010 Share Posted September 25, 2010 (edited) Say i have a forged motor for argument sake a rb26.The motor has a full forged bottom end crank rods pistons and so on. The kit is pulled out of the block and not marked, So piston/gudgeon pin/rod are not marked where they came from.Even the rings are in a pile.... Any one offer some insight if this can go back together saftly Is that a massive head #$%^ and if they don t go back together the correct way is it catasrophic failure time? Any one shed some light on this as im not a mechanic. As much detail as possible please. Edited September 25, 2010 by Gtir-keiron Link to comment https://www.sau.com.au/forums/topic/338094-motor-pull-down-and-put-back-togetherneed-a-mechanics-point-of-view-please/ Share on other sites More sharing options...
N1GTR Posted September 25, 2010 Share Posted September 25, 2010 Give it to a mechanic to assemble. No stress and it gets done correctly. Link to comment https://www.sau.com.au/forums/topic/338094-motor-pull-down-and-put-back-togetherneed-a-mechanics-point-of-view-please/#findComment-5465282 Share on other sites More sharing options...
DVS JEZ Posted September 25, 2010 Share Posted September 25, 2010 Everything can be measured to ensure that it goes together ok. Has the motor been running then pulled apart? Link to comment https://www.sau.com.au/forums/topic/338094-motor-pull-down-and-put-back-togetherneed-a-mechanics-point-of-view-please/#findComment-5465324 Share on other sites More sharing options...
The Mafia Posted September 25, 2010 Share Posted September 25, 2010 Personally, I'd get new rings and bearings, hone it and re-assemble. Everything else should be fine. This way you have piece of mind. Link to comment https://www.sau.com.au/forums/topic/338094-motor-pull-down-and-put-back-togetherneed-a-mechanics-point-of-view-please/#findComment-5465337 Share on other sites More sharing options...
Gtir-keiron Posted September 25, 2010 Author Share Posted September 25, 2010 Its been running,Pulled apart My mechanic told me that the gudeion pins have to go back where they come in the same way they came out. from also the pistons have to go back on the rods they came from and so on and so on. I was planning on doing new rings and bearings but i wanted to know about the other stuff. My mechanic is anal......Things have to be perfect.. in his world of putting motors together. just wanted a performance opinon. Link to comment https://www.sau.com.au/forums/topic/338094-motor-pull-down-and-put-back-togetherneed-a-mechanics-point-of-view-please/#findComment-5465448 Share on other sites More sharing options...
Supa Steve Posted September 25, 2010 Share Posted September 25, 2010 (edited) Its been running,Pulled apartMy mechanic told me that the gudeion pins have to go back where they come in the same way they came out. from also the pistons have to go back on the rods they came from and so on and so on. I was planning on doing new rings and bearings but i wanted to know about the other stuff. My mechanic is anal......Things have to be perfect.. in his world of putting motors together. just wanted a performance opinon. Your mechanic is a guy who is trying to pose as someone who knows what he is doing. Linish pins, resize and balance conrods as well as balance pistons and it doesnt matter what is what. As when they are balanced the piston and pin are matched to avoid taking too much off the piston. If you had a light piston and pin matched together you would have to grind excessive material off all the other pistons to get them to match up. Someone who suggests putting an engine together without doing this clearly has no idea. Id say you grab your gear and go elsewhere mate. A quick look at the early failure poll thread will show that there are a lot of guys who take on RB's without the experience with the poor customer footing the bill. Ive screwed together quite a few engines in my time but when i opted for a big dollar bill i went to the experts so the job was done right. Edited September 25, 2010 by Supa Steve Link to comment https://www.sau.com.au/forums/topic/338094-motor-pull-down-and-put-back-togetherneed-a-mechanics-point-of-view-please/#findComment-5465514 Share on other sites More sharing options...
Gtir-keiron Posted September 25, 2010 Author Share Posted September 25, 2010 Oh thats not what im saying. Im saying he wants to know what gudeon pin came out of what piston and what rods it was connected to and what order the pistons were in. Like i said hes anal about things when it comes to building motors.Hes a very good mechanic with alot of exp with RB Sr and nissan engines but sometimes i feel hes over the top and i don t want to spend money where i don t need too. he already said i would have to replace the rings and bearing and i new that from the start. Thats why im asking what my options are. If i can get it all balanced and set up to as new or better then it should not be a problem yes? thats why i wanted detailed infomation so i had options rather then him telling me i need to replace pistons and pins and things like that. Link to comment https://www.sau.com.au/forums/topic/338094-motor-pull-down-and-put-back-togetherneed-a-mechanics-point-of-view-please/#findComment-5465536 Share on other sites More sharing options...
Supa Steve Posted September 25, 2010 Share Posted September 25, 2010 Oh thats not what im saying.Im saying he wants to know what gudeon pin came out of what piston and what rods it was connected to and what order the pistons were in. Like i said hes anal about things when it comes to building motors.Hes a very good mechanic with alot of exp with RB Sr and nissan engines but sometimes i feel hes over the top and i don t want to spend money where i don t need too. he already said i would have to replace the rings and bearing and i new that from the start. Thats why im asking what my options are. If i can get it all balanced and set up to as new or better then it should not be a problem yes? thats why i wanted detailed infomation so i had options rather then him telling me i need to replace pistons and pins and things like that. i think you may have missed it so i will put it a bit more direct. it means 3/5th's of f*ck all where what came from except for the rod caps which are generally numbered and anyone who tries to tell you otherwise is giving you incorrect information. Clean everything up and weight-match to ensure best clearance and minimum grinding of pistons. Rods NEED to be resized and balanced to ensure they are exact. If he is as pedantic as you state then this should be a given for him to understand. Pistons and pins will only need replacing if the pin has flogged out the bore of the pistons and/or bent the pins. properly prepped and assembled serviceable parts will have your engine as good as new. best of luck Link to comment https://www.sau.com.au/forums/topic/338094-motor-pull-down-and-put-back-togetherneed-a-mechanics-point-of-view-please/#findComment-5465713 Share on other sites More sharing options...
Gtir-keiron Posted September 25, 2010 Author Share Posted September 25, 2010 thank you mate. Link to comment https://www.sau.com.au/forums/topic/338094-motor-pull-down-and-put-back-togetherneed-a-mechanics-point-of-view-please/#findComment-5465778 Share on other sites More sharing options...
Adriano Posted September 25, 2010 Share Posted September 25, 2010 As steve said, everything can be measured to confirm where it goes, however if there is no discernable difference when measuring, then it doesnt matter where they go. Then check balance and assemble. Link to comment https://www.sau.com.au/forums/topic/338094-motor-pull-down-and-put-back-togetherneed-a-mechanics-point-of-view-please/#findComment-5465861 Share on other sites More sharing options...
WARLORD Posted September 26, 2010 Share Posted September 26, 2010 Give it to a mechanic to assemble. No stress and it gets done correctly. +1 Link to comment https://www.sau.com.au/forums/topic/338094-motor-pull-down-and-put-back-togetherneed-a-mechanics-point-of-view-please/#findComment-5465959 Share on other sites More sharing options...
