Yo yo.
R34 GTsT. 3" turbo back exh- Walbro 500 hp pump- JustJap Turnflow FMIC- Mushroom filter in box- Standard ECU, Injectors and AFM- Greddy profec B- Greddy RS BOV plumbed back into intake.
I've been having some real headaches with how my car puts down the power. In a nutshell, anything over 7psi (my Hi boost is set to 9,5) turns my car into a pig rich fuel guzzling, retardation machine. At first I thought it was R&R, and changed my plugs, AFM, and got hold of another standard ECU. Coilpacks are fine, and no boost leaks as boost comes on consistent and strong.
So I took it to Pulse Racing to see how it looked on the dyno. Check out the pics attached. Their Dyno reads at it's lowest A/F point of 10:1. My cars AFR flatlines at 10:1 or possibly lower right from the beggining of the run. Check out the crazy power dips to and a max of 126 rwkw.
I need some help in getting some ideas what the problem could be. Replacement standard ECU made no difference, and simply "chucking in" an aftermarket item isn't going to fix the problem either...
Tuner recons it's not the 02 sensor, coils, plugs, boost control, but pretty much tried to "sell" me the idea of an aftermarket ECU, which really, is a bandaid fix to the actual issue. I want to diagnose the cause of the issue. Any help is appreciated
Cheers
https://www.sau.com.au/forums/topic/338107-worst-dyno-results-ever/
First thing I saw was Walbro fuel pump, did you use the stock wiring (6v / 12v depending on load) or did you give it alternator voltage like A/M pumps such as Walbros need?
i hardly think theres any problems with lack of fuel flow looking at the graph....
Yo yo.
Cheers
Are you sure the injectors are stock? Something doesn't add up... Checked fuel pressure?
He suggested an aftermarket ecu because he cant adjust anything without it.
To Moodles2, It was happening prior to the Walbro pump install, and if anything, it's getting too much fuel rather than not enough. the Pump was installed by Autosport engineering, who I dare say know what their doin. It wasn't a backyard job.
To Scotty, I haven't checked if the Injectors are standard. I would assume so as but will check that out for sure.
My thoughts are it's not necessarily the ECU at fault here. yes i kno that their is a safe map for knock etc with the Nissan standard unit, but there is no way that the map is "lets drop AFR to 10:1 through the entire rev range"
Get an ecutalk or other consult reader and get some idea of what is going on - injector duty, afm readings (can you swap out the afm with someone?) And get a Nistune chip so that you can actually try to tune it. It will also help to identify problems.
How has no one mentioned the fact he thinks he owns a R34 GTST? :D
Haha yeh i noticed that.
So is that run on stock boost?
Did u try running a higher boost setting. Like 12 ?
Check coolant temp sensor too. Its like its on cold start enrichment
check the boost sensor is hooked up, and secondly that the boost source for the BOV is connected. If either are missing it will do that... as will a split hose (cooler)
Second dip is normal as the std ecu has a big timing drop in i, run std boost and dip goes away... or a quick remap removes it straight away.
yes
ECR33 has excess airflow protection
ER34 has excess airflow protection
ER34 also has excess boost protection via the 2nd map sensor that runs to the ECU
its likely you are just tripping that out, youll need a remap, a map sensor cut device, run it no where and crimp the vac line or get a stand alone
Lo boost on Greddy - gain 28% set gain 13% Start gain .46 gives me about 7.3 peak boost
Hi boost on Greddy - gain 38% set gain 18% start gain .55 gives me about 9.3 peak boost
Running "lo" boost is fine
Running "hi" = what you see on the dyno charts
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
