Damn , that was quick , got new wheels for it yet??
yep, I spent 1 day stripping it 3 days of panel work/prime, and 1 day to paint, I have gtst wheels to go on when the 5 studs done but im in no rush at the mo, other bills GRRR
  • Replies 57
  • 2 months later...
Good thread mate, love ya work.
Its nice seeing some progress happen... But 4 days for a repray, thats insane!! Im a spray painter so i can appreciate ya what your've done there.
Did you paint it, or someone from ya work?? How did they/you go about painting it? Doors in/out and bars in one hit then car with boot an bonnet on in another session?? Im planning to respray mine soon so i wouldnt mind hearing more about how ya did yours just for idea's.. Im thinking of doin mine in a subaru colour, silky white three layer pearl.
Awesome stuff man, more photo's of the finished product would be awesome...
cheers guys, I'll put a whole lot of pics up next week when im back in town,
to break down the respray, i did it over a week, but on 5 of those days, (12 hour days) my bad, I told a fib. I already stripped and repaired the boot lid roof and bonnet a few months earlier, but yea 1 full day to strip it down, ( all panels off, complete strip bar the engine bay) 1 whole ffffn day to fix the passengers side sill it was roooooted, the next day was just fixing scattered dents and wobbles and sanding off old crappy dodgy acrylic paint, and I got the painter at work to prime it that night, left it for a day then spent 1 day blocking and prepping it. then a day of painting, (same painter) 3 times in the booth, car and front guards first round, in and out. Doors next, in and out, then the bars bonnet and boot last.
If time wasnt a factor I would have left the primer to cure better, cause it has shrunk back a bit, not that anyone notices, its lookin schmik
For you Even Flow,
I used
PPG 1 shot epoxy etch,
HS primer << not real keen on it, but can't argue with FREE!
PPG DG liquid Audi white
I thought about pearl, but I just wanted simple and easy to touch up,
For you Even Flow,
I used
Awesome dude, yeah the more times you can go in the booth with the least amount of parts the easier it is and the nicer the job i reckon. Epoxy etch is some good shit and HS primer is ok, i'm personally not a fan of PPG's primers, they seem to have less filling power and body to them, i use lesonol at work and that seems to need one or two less coats...You also saved cash using a DG 2pac paint, the three layer plus clear is gonna kill my wallet!!
Three layers can be hard when repairing them, to get a good match. But the advantage of me painting the car is i will remember how i painted it (how many coats of the top layer) so it shouldn't be a problem if i do have a whoop-see down the track.
Don't worry about the shrink back, a good ol' cut n polish will fix that if it bothers ya. But like you said, most people cant tell anyway! haha
Keen for pics, cant wait.
sweet, yea I know pearls can be an absolute bastard, but hell pearl white, its made for cefs
I'm getting slack havent taken any pics yet I will try this weekend, only update I have is a new steering wheel i got in NZ last weekend
  • 3 weeks later...
  • 4 weeks later...
Hey mate, quick question. When you did your respray did you have to replace the rear window rubber that gets euro'd in around the edge...?? The rubber that the trim clips into that surrounds the rear window?? i need to track a brand new one down and need abit of help. Hope you can point me in the right direction...
Cheers Jared
The respray was only partial, mostly just the bonnet, bumpers and door, so not sure about the window rubber sorry.
Pretty sure I saw you on Military Road at Grange around 10:30 last night?
Yeah i was around that way about that time, went for a cruise with my mate in his jzx100... i also saw you thurs turning on to trimmer off fredrick prob round 1.30pm. Was sitting in traffic spewing, just wanted to get home after having a bloody wisdom tooth pulled.. :mad::down::miner::rant::D :D
I was going to get the rear window removed, but I found out I couldnt get that rubber easily, I could have through a glazier in NZ and ex japan, when avalible, but that was going to be a 4-6week wait.
so thats the only bit I had to mask up
Wow. devo...
I'll have to start making some calls and see what i can find, cause i need one!
Cheers mate
  • 4 months later...
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
