Hey Stao.. i would be interested in ur further testing and gladly would accept.. what do u suggest?
Why would you agree to do R&D for a product you have bought which has promised results...R&D should be done by the manufacturer before a product is released...not after its sold and failed to meet requirements....
And to hypergear...its BS that a 2530 won't hold 20psi because the rear is too small...even a 2510 or a GT-SS will do 20psi...
Limpus this specific turbo is not released. I'm testing lots of different combinations on mine and few others for the best result. and in general speaking there is not best results, there can only be better results. All prototype units has been offered at a discounted price with the tester knowing what it is.
HKS2530 can not hold 20psi by 7000RPMS internally gated on a stock RB25det setup. There are plenty of sheets proven it can't, find me one that can.
1st lot of graphs compared to the 2nd - its a lot better...
However 4000rpm you still only have 140rwkw, for a peak of only 230rwkw on 21psi IMO that is poor.
You'd expect that kinda power delivery from a 600hp turbo - not a 400hp one.
.86/.82 is a bad rear end choice for a start. Any why boost would be nosing over that hard is amazing... Certainly I'd have issues with that.
As an example have a look @ the two graphs below simply taken from the RB25 dyno thread.
180rwkw @ 4100rpm, that is a whopping 40rwkw more than your setup for pretty much the same end result, and less boost as well to boot.
http://www.skylinesaustralia.com/forums/post-a279850-
This next graph... 500-550hp GT30, making 160rwkw @ 4000rpm. 20rwkw more @ 4000/40rwkw more in the top end
http://www.skylinesaustralia.com/forums/post-a288761-
Now my aim was not to bag your setup - simply to highlight there is a pretty big problem.
I'd be investigating the boost control firstly - try get it holding 20psi to redline.
If it wont (even with the gate held shut), then it's just a poor turbo.
Ramp rate is also something to look @ i had a GTR in here with a dyno graph from a well known shop and it was only possible to replicate it with an artificially high ramp rate (brings it on alot sooner).
Unfortunately ramp rate is used alot to skew results.
Not saying that this is the case here but it brings up the old adage that the only good comparison can be done on the same dyno.
Wouldn't a low ramp rate bring on a turbo sooner?
Stao - I was thinking of a 52T 2871 with a T2 0.86 rear on an adapter. The price of those things is sooo cheap. I'd estimate full boost at 3200rpm and should be enough to make 330rwhp.
nah, think 1st gear vs 4th gear... 4th gear more load = quicker spool.
Oh ye look no doubt - but i don't think any ramp rate is going to alter the 40rwkw odd that this is down on the midrange.
20rwkw, maybe... but 40rwkw when talking about what, 140-170rwkw, thats a fair percentage ;)
Hmmm, well here is a dynograph of my RB20DET with a Disco Potato, .82 rear. Almost reaches 300HP. I used an adaptor purchased from Garrett to mate the T25/T28 flange to the T3. I am looking to change the rear housing to .64 for more response. This is 1 bar boost.
Edited by liampire
  • 3 months later...
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
