I had a pair of Supervision Deluxe's in my old Accord - didn't like 'em too much - too directional and not dispersed enough
Currently have 6000k Phillips HIDs in my coupe and love em (good spread and good intensity). Would like to go a bit brighter (around 7000k) but they do the job - so +1 to Phillips. ;)
I sourced 'em through a mate who was doing a bulk buy so will find out where he got them from and will get back to you.
P.S - that link David posted is really good!
https://www.sau.com.au/forums/topic/338181-hids/#findComment-5468405
sweet... thanks for the site!
and yeh if you could find out where he got them from :D
btw, i want the lights aswell where u got your number plate :)
looking through couple pics and came through this
looked hot, wanted something similar to that ?
Got my number plate lights from Jaycar Electronics, costed me like $5-$10. :P They're just white LEDs (U can get blue, red, yellow etc)
That pic you posted is pretty sweet. Is your V35 a 2006 model? If you notice, they've got projector lights, which only got featured on the '06 and newer models :/ And Projectors + HIDs = Even Better LOL. Majority of the V's in Aus though are pre '06.
If you have a look at the black one - it's running 6000K HIDs, a more whiteish tinge to the light. 6700K and above get a bit more blueish (the second pic). Have a look and see which ones you prefer. I think the legal limit in Aus is 6000K, but I could be wrong (who cares right? :P).
https://www.sau.com.au/forums/topic/338181-hids/#findComment-5468814
and yeh if you could find out where he got them from :cool:
Spoke to my mate. He got them from www.gadgetmaster.com.au
I had a brief look, doesn't look like they stock the Phillips kits, however that being said, I think the current kits they stock look pretty decent.
Have a look.
https://www.sau.com.au/forums/topic/338181-hids/#findComment-5471457
Currently have 6000k Phillips HIDs in my coupe and love em (good spread and good intensity). Would like to go a bit brighter (around 7000k) but they do the job - so +1 to Phillips. :)
A little bit off topic but 6000k refers to the colour temperature not the brightness so 7000k doesn't mean they will be brighter. Just means they are further away from being "daylight" colour and closer to the blue spectrum. 5200K is a much more of a natural colour temperature.
https://www.sau.com.au/forums/topic/338181-hids/#findComment-5471905
Well the colour rating also indirectly affects the lumen output of the lamp. The higher you go up the colour range, the less lumens outputted.
To go brighter really, you need to move down the colour scale.
Output is generally optimum at around 4300-6000k. Any higher and you start losing light output and it will get harder to perceive 'depth' as it's hard to render with the blue/purple light.
I had factory hids and they were 4300k. Almost a perfect match to sunlight, slightly yellow and very easy to 'perceive' things at night.
https://www.sau.com.au/forums/topic/338181-hids/#findComment-5472008
Agreed. Not sure why I used the word "brighter". ;)
My lights are bright as it is, however, there's something sexy about going a little bit into the blue part of the spectrum. Just a tad bit not ridiculously blue.
Cheers for pointing that out though :)
https://www.sau.com.au/forums/topic/338181-hids/#findComment-5472271
what are 'projectors' ?
is there like normal HID's and HID - Projectors ?
HIDs are the types of bulbs. Instead of burning a filament, IIRC there's a gas inside the globe, and when you pass a current through it, the particles are excited and they emit a light. The color of the light, by the sounds of things, is dependent on the voltage being passed through it (which is strange because I thought it'd be affected by the gas?)
The projectors are convex lenses which refract light back down onto the road. You know how you pass people and get blinded by their headlights? The HIDs lessen the impact of that.
Because HIDs are VERY bright, it's a considerate action to shine them through projectors so people don't swerve towards you, as has happened to me. :ermm:
Rough throw-together; http://www.skylinesaustralia.com/forums/Hi...ad-t339646.html
Edited by SKITTLES
https://www.sau.com.au/forums/topic/338181-hids/#findComment-5485747
Projector lights are a type of housing for your headlight. They come in both halogen and HID form. They use elliptical reflectors which allow a more accurate light dispersal (some argue 'brighter' too) than normal headlights using parabolic reflectors - in practice they are similar to how a slide projector would work.
http://en.wikipedia.org/wiki/Headlamp#Proj...soidal.29_lamps
Projectors headlights with HIDs are the bomb!
https://www.sau.com.au/forums/topic/338181-hids/#findComment-5485753
looking to get HID's for my car
just wanted to know where i get some and which ones would look good on a black v35
cheers
http://www.dealextreme.com/search.dx/search.HID
I got 10,000K HIDs on my 33, they're the sex. Might nab a photo tonight *writes down on hand
https://www.sau.com.au/forums/topic/338181-hids/#findComment-5485821
yeh show us a photo :)
so i want Projector HID's 6000k..
any hope that i can go to that sells them and installs ?
lol
If you want projectors, you're going to have to buy the '06-'08 projector headlights online. Something like this: http://cgi.ebay.com/ebaymotors/OEM-G35-COU...sQ5fAccessories
There are various companies which make after-market projectors with HIDs (e.g. cincity designs) - however, I think they're pretty pricy. Also, if you order them from the US you might have to check if you can adjust them since the light would be directed the other way (cuz they drive on the other side). That's all I know - maybe Jacob has more insight into this.
Good Luck
https://www.sau.com.au/forums/topic/338181-hids/#findComment-5486188
  • 4 weeks later...
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
