I got my OBDlink connected over wifi to HobDrive, there was an nm35 profile under Nissan when I went looking. I'm guessing thats your config Matt.
The first page of sensors seems okay but the rest seemed a bit useless. Not the most intuitive app but it seems to have a fair bit of functionality.
If you goto sensor list under screens you can see all sensors data if you click on them. I'm trying to get them transferred to the main screen.
I was able to read and clear a fault code today.
On another note I worked out how to bypass my rpm limit, revved to 8400rpm and fried my alternator bearing(glowing orange) interesting part is the engine still increases in power over the OEM limit. :D
post-49288-14446531082741_thumb.jpgpost-49288-14446531231962_thumb.jpgpost-49288-14446531332312_thumb.jpg
  • Like 1
The dark theme for the 'Full' version looks so much nicer than the demo.
Have you noticed whether the fuel consumption tracking it does is accurate? I never found the Informeter to be anywhere near the actual scenario for me.
Did you bypass the rev limiter via HobDrive or the EMU? My Impul ECU already lifted my rev limit, Im happy with where it's been set but Im curious as to whether the speed limit could be removed via this also? (However, again, my impul already took care of that)
Bypass was via the EMU. Speed limit can't be adjusted by the EMU
Working on an EMU speed input so I can program launch control with ignition retard.
I haven't setup the parameters for fuel consumption. But I imagine the data would be accurate if the input settings are accurate.
Edited by BoostdR
  • 3 weeks later...
I can confirm the HobDrive doesn't clear the brake wire cut mod CEL. Comes up as 4WD status high or similar. All other code display and clear ok.
I'm haven't sent in my custom Stagea screen layout request yet although it has been approved.
I have my wide band simulating the narrow band so I plan on having lambda translated to AFR with a line graph background, intake temp, coolant temp, ignition timing, short and long term fuel trims, trains oil temp and the boost sensor output translated to psi
  • 4 months later...
Been following this for a while now trying to get it working on my car. After a couple of dud bluetooth ones I saw you got the Vgate so found a cheap one on aliexpress for about $25USD which seems to do the trick with Hobdrive trial.
Do you still have the promo code for the full version Matt? I'm keen to give it a whirl.
Also, how long did it take you to do diagnostic scan? I've had mine on the diagnostics screen for about 15 mins and it's still saying 'initializing'. Is there a 'scan' or 'on' button I'm missing?
  • 1 year later...
Thread resurrection... A little help please those who have got HobDrive and VGate to work together.
I have a VGate wifi wotsit. I have the full version of HobDrive on my iPhone. Vgate plugged in, power light is on, OBD light is off, and Link light blinks. HobDrive is set up using the NM35 vehicle profile that is saved on there. HobDrive can see the VGate but not the car. What am I doing wrong? Any ideas? Messed about with the settings plenty but honestly don't really know what I'm doing so not sure that's helped!
All ideas appreciated :) TIA.
John
  • 5 weeks later...
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
