Ran a direct wire from my gauge to my oil temperature sensor on my oil re-location kit. All I had for the way of wiring was some 15amp Auto Wire. I wired and soldered it all up and doesn't seem to register / pickup the sensor. Could this be the 15 amp wire, or doesnt it matter what kind of wire you use?
https://www.sau.com.au/forums/topic/338218-oil-temperature-sensor/
doesnt matter on the type of wire as its only a signal and not power supply. if disconnecting the wire doesnt make the guage move try touching it to ground for a second and see if it moves but not more than for a second. if that doesnt make it move then the prob is wih the guage. if it makes it move then its with the sensor
