I'll hopefully be making my first driving appearance at the new WSID either this week or next to try and get a 13.8sec (down from 14.46sec) with only: K&N Panel Filter, full 3" exhaust, 7psi and 225/50/16's.
I had a 2.23sec 60ft'r but was plagued with axle tramp. So if I can remove the axle tramp I think I have an easy 0.5sec begging to be wiped.
(honestly though i'd just be happy to get off the botton of the SAU Drag list :O )
https://www.sau.com.au/forums/topic/33823-stock-33-times/#findComment-679268
i know this isnt relevant to the "STOCK" issue but i only had pod, cat back 3 inch, 13psi, 215/50/16 on stock rims and ran [email protected] so its doesnt take much. i got a 2.09 60 foot!!!! but havent been able to beat it even after doing my exhaust from the turbo. best i managed after that was [email protected] 2.28 60 foot. I might go and race this weekend 28/2/04 at the test n tune to try and beat it. Gonna try and raise the suspension up to get some squat. Oh by the way i had my tires let down to 20psi
https://www.sau.com.au/forums/topic/33823-stock-33-times/#findComment-695586
no idea how you guys race with 215's and 225's ive got 255's on my 33 and it still chirps in second and does mad launches. no idea how u make it keep traction with 215's and 225's
stock with only pod, no zorst, stock boost etc.
https://www.sau.com.au/forums/topic/33823-stock-33-times/#findComment-711579
i agree,i have a pod, cat back zorst and 255's and mine wheelspins in second a fair bit (alot larger than a chirp) and chirps third in power shifts (not flat changes)
https://www.sau.com.au/forums/topic/33823-stock-33-times/#findComment-713545
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
