For some reasons, when I'm driving at night (with my parkers & HIDs on), my parkers/HID/dash/gauages lights just flickers when I'm indicating. And my voltage meter in my R34 just jumps up and down.
Anyone know why?....
I did a test on my battery with a multimeter.
When car is off: 17.3v
When car is on: 20.8v
When my driving lights are on: 20.8
When I indicate with driving lights on: 20.0v
Not sure why the readings are so high, as I've been told the voltage should be around 12-14v. And the reading on the multimeter is different to the voltage gauage I have in the car.
Any help on this would be awesome! :down:
did you have your multi meter on the right setting? the V with the dotted line. if you had 20v you woulda blown the ass out of your cd player etc by now. does it only do it when indicating in one direction or both?
Hmmm.... I think I had it on the right settings lol, I'll do another check.
But nah, it happens when I indicate left, right and hazard lights too.
if you are getting 20v then you have a serious issue. i'm suprised nothing has blown yet. my grandparents camry had the voltage regulator let go and it was charging 18v at idle and it blew a heap of bulbs (i think only the interior light and the glove box light were about the only 2 that didn't blow), fried the wiper motor even though the wipers weren't turned on, and a bit of other stuff.
Basically, the alternator can only just keep up with the demand for current. When you turn on the indicator, it's the "straw to break the camels back", and the indicators "steal" a bit of current from all the other electrical items.
You might need to upgrade the power of your alternator.
im sure a gtt would have a 70-85 amp alternator. HID,park lights,indicators and engine management would only be about 20-30. otherwise everyone would have the same problem...
Sorry guys, I just tried checking another car with the same multimeter and it seems like it's reading high as well, so just ignore the 20v readings.
But all in all, the voltage shouldn't just drop about 0.8v when I indicate anyway, should it?
I was thinking it is something with my alternator as well, because the lights flickers more when I'm in idle.
    • Probably being in IT for 2 decades, and spending my time documenting trees worth of shit and also being on the receiving end has taught me a thing or two.
    • Why's that depressing, wouldn't it be able to go indefinitely until the battery gets old and craps itself? If it's constantly on charge/maintaining charge, won't that keep the battery healthy?
    • One of my concerns initially was if something catches fire somehow.
    • I think I know what you mean. I saw the same thing a while back, I think either the images on the website were wrong or the model was slightly updated. It was weird when I first looked at it, same model but different looking unit.
    • At work we've got a smaller version of the Projecta that Duncan posted above. At home, I have an ALDI trickle charger. Ive had it for about 8 years now. Only issue with it, it's a smart charger, so if the battery is dead, it won't bring it up, but I have a variable power supply that I limit current on, and set to a max of 14.4v. once it starts charging up, I put the aldi unit on and remove the variable PSU. ALDI one will do 12v, or 6v, then has mode for "car" "motorbike", and "snow". With car or motorbike more for its internal workings, and snow is the trickle mode. I have a battery in the garage that lives on this charger for about the last 18 months now on Snow mode. When I need to charge my other batteries (eg, ones that have died in a car), I get them started and then run it on car mode. Voltage is always sitting really nice, and hasn't killed a battery yet. that charger isn't good for things like Lithium batteries etc, I'd only use it on Lead Acid.
