Not from mine. Otherwise why would I be asking.
Which program are you using?
If you're images are in bitmap or similar, there should be a "Save as" or an "Export" option.
When you export, change the format to something such as PNG or JPEG, this will rapidly decrease the size. If you've taken the photo off a camera, or if its high resolution, you might want to scale the image down to 1xxx pixels, so something like 1200 x <?> pixels or smaller ;)
Less pixels is of course a smaller image and smaller file size.
Oh, blind_elk if you want to do screenshots from webpages, and you use FireFox, my choice is FireShot. Its a little heavyweight but you can add little notes on the image before saving it: https://addons.mozilla.org/en-US/firefox/addon/5648/
Any images uploaded to SAU - are compressed when inserted into a post as Paul posted above.
You must follow Pauls method however for it to work that way.
If you hotlink them from say, photobucket or some other site, sometimes they will compress depending on the users resolution/screen size.
It varies in that situation obviously.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
