Hey guys, my pride and joy is up for sale as im building a new house.
The car is a 1994 R33 GTS-T, type M, 5 speed manual, 105,000kms, Climate control, power windows, mirrors & steering. Interior is in top condition, only the drivers seat has the usual wear on the side.
Being a type-M the car has Active Limited Slip Diff, 4 spot calipers on the front and 2 spot on the rears, GTR rear wing,
400r front bar and more.
It has been serviced every 5,000kms and has rego till end of April 2011.
It has the following modifications:
Aftermarket computer (Adaptronic) with 3bar map sensor (Tuning software and cable supplied)
Adaptronic vidigauge (7 Electronic gauges displayed on DVD screen)
3" X-Force stainless exhaust with 4" cannon
Innovate wideband O2 sensor
Splitfire coil packs with NGK iridium plugs
Thermo fan
K&N filter
Turbo timer
Aftermarket plenum with 80mm throttle body
550hp Walbro fuel pump
Front mount intercooler
Steel blade turbo
Catch can
BOV
HID headlights
Optima battery
Electronic adustable boost controller
Boost gauge
Alarm/immobilizer
Nizmo short throw shifter and nizmo gear knob
DVD player
New gates racing timing belt replaced at 98,000kms
New tyres and wheel allignment
It made 250kw at the wheels on 14psi.
Car is located in Wollongong, NSW. No test pilots or tyre kickers.
Plates NOT sold with the car. $11,000 ono
Call David on: 0418 626 519
Edited by whistle
https://www.sau.com.au/forums/topic/338247-nsw-fs-r33-gts-t-type-m-11000-ono/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
