Hey guys,
A clean up of my last thread. Turbo is sold! So here goes.
* RB25DET - 127xxxKM, cyl 6 slightly less compression than the other 5 on 180. Manifolds included, no injectors or rail. $1000 (have interest already)
* R33 RB25DET 5 Speed Gearbox conversion - 127xxxKM, runs well, car is mostly stock and has not had much abuse. Stock clutch, pedal, lines, etc ra ra ra, all included. $1200 FIRM.
* 700cc Injectors - High flows, just done, flow matched work perfectly. In factory rail with reg $450
* Z32 AFM with plug - Near new bosch item purchased from justjap not long ago $200
* Splitfire S1 coilpacks - $400
* Stock coilpacks in good condition - $100
* Stock R33 crossover pipe with BOV - $80
* Stock R33 intercooler - $80
* R33 alternator $80
* BRAND NEW JJR Stealth FMIC. Fitted and driven back in the garage before my turbo sold. I paid $550 from Just Jap 2 weeks ago. Yours for $480 Firm.
* R33 Engine wiring harness, coilpack and injector harness included. VGC. Unmolested - $150
* HKS mushroom pod filter. Suits RB and Z32 AFMs, bolts into place. - $100
* R33 stock shocks and springs - $100
* R34 stock shocks only - $50
* RSR Ti2000 springs, suit R33/34 (I think R32 also) - $100
More to come as I strip the engine bay. Postage on smaller items, pickup only on larger.
Bankstown area Sydney.
Cheers!
https://www.sau.com.au/forums/topic/338255-fs-r33-goodies-stock-moded/
Are you neg on the above items? and would you do a better deal if purchased together?
Cheers Jason
Injectors and AFM SOLD
Added:
* R32 ecu socketed and remapped for 3037 (3076R), 700cc, Z32 - $150
* R33 RB25DET factory ecu - $100
* Green label RB afm - $100
Gearbox is now $1200 with fork/slave/clutch/flywheel
Pedal box and master will be kept for my conversion.
This price is generous as it is, no more low balls.
Cheers
  • 1 month later...
  • 5 weeks later...
Hey guys,
Very sorry for ignoring my thread for so long, possibly best to PM in future.
Geabox is now sold, clutch and flywheel assy still available.
Long motor still available.
Stock shocks and springs in regular old condition, pics available - no obvious leaks or anything and they drove fine.
RSR springs were actually for an R34 and dropped the car to a good height. I have a photo of the front of my car if still interested (with the RSR's fitted)
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
