I got the idea today to modify the stock actuator to hold more pressure on the wastegate flap. I want to see if it holds boost better.
A simple spring mounted to the shaft did the trick.
Without spring, 14psi cracked the flap.
With spring, 19-20. Should do the job but can I swap it into the car? Bloody tight down there.
https://www.sau.com.au/forums/topic/338266-i-cant-hold-boost/
what metal is the spring made of?
exposing steels to temps over 200°c can alter the internal structure of the metal and will affect the "strength" of the spring
Im sure it will be fine, its a fair way from the exhaust housing and plenty of room for a sheild. Worst case it fails giving me lower boost anyway, as im map sensored it should adjust the mixtures with no issues.
  • 4 weeks later...
Havent installed it yet, because its a PITA to get down there. Next time the intake is off...
lol i think you should do it on wednesday when i come by. :)
i could help you as well if you like?.. maybe hold a light? im gonna get hold of a resistor tomorrow as well.. give me a call when your free.
lol i think you should do it on wednesday when i come by. :down:
Sounds good, I need to fit the replacement rear springs too, I will give you a hand between swigs. :P
Ghetto mods to the torque converter lockup, Niiice... lol.
whats the torque converter mod??? i might need it as mine is fooked :D
Cant tell you all my sercrets. :)
Its just cutting the torque converter lockup solenoid wire at the TCM and running it through a resistor to simulate the solenoid load. (so the trans ecu doesnt fault)
This will disable the lockup completely and allow the cooling circuit to remain on also. (they are both part of the same solenoid) Between that and a shift kit, the box should be fine, providing you have the nissan fluid in there...
Cant you modify a stronger actuator to fit?
Its a weird one, I would need to make a new shaft and stuff around. I will probably be upgrading engines in 6 months with a GT35 so no point buying a $100 actuator and butchering it to fit, its only a stiffer spring anyway.
This will work out free and easy to do, and if it can hold the boost a bit longer it will be worth the small effort.
yeah just looking at the pic it is a weird one, also noticed the date, and last i spoke to you i think you were already holding 20psi so guess i should get with the times hey... :)
No, its still not holding, the 300kw run was at 17 psi, I would obviously like to hold 20psi flat line at least with the ethanol, not sure the engine can hold that though, will have to wait and see. :D
Cant tell you all my sercrets. :P
hmm, this sounds good. I could setup a switch to enable the lockup circuit again for when im highway driving (like going to melbourne for my tune)
No, its still not holding, the 300kw run was at 17 psi, I would obviously like to hold 20psi flat line at least with the ethanol, not sure the engine can hold that though, will have to wait and see. :P
are you using the factory boost solenoid?
do you have an EBC? if not, get one!
Blitz spec R, should normally do the job but im guessing the flap is blowing open under the pressure in the manifold. We only have a low pressure actuator due to the "low boost" setting at cold start.
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
