Mechanical.
Pretty sure the above posts have covered it.
There is a metal "lever" that goes up and down, over time when you close the boot it slowly slides down (mine does this now) and every few days just pull it up and it shouldn't happen again until its back down.
https://www.sau.com.au/forums/topic/338277-boot-wont-open/#findComment-5467286
just a suggestion but what you can do is to use a cable tie to keep that metal thing up. loop it around the little lip that comes out and through a hole.
annoying i know if you want to use the valet mode but better than going to open your boot with the lever and being like WTF it won't open.
https://www.sau.com.au/forums/topic/338277-boot-wont-open/#findComment-5472699
