I have a series 1 with a forged RB26 engine and manual box.
Have decided I need an LSD, Question is what will fit ?
Ideally I would like to keep the front as is because changing it is more work than the rear. Ive found an RS FOUR S and can have both diffs if neccessary
Anyone know if the ratios are the same as series 1 cars or indeed if the diffs will even fit .
Thanks in advance for any help.
Can't say for sure but I think they are the same: just under 4.1
I'm going for a GTR diff partly for the thicker axles (and also because the engine is out anyway I can change both). So I guess you haven't snapped any axles yet?!
Not yet but I am going to santa pod next weekend so if anything is going to go it will probably go then.
Main question was whether the RS Four S had GTR diffs as I know it has HICAS . If not then the difffs are probably the same ratio which is good news.
GTR have 6x1 bolt pattern for the half shafts Stagea are 3X2
Be sure to post up your times!
The joys of not owning a RSfour S from the start.lol. Suppose it was afactory option. Going nismo should save quite a few hassles, has a install kit included. I found this helpful when looking into an 1.5 or 2 way lsd option. Part no seem to be the same? Download the installation manual and check diff type -compare (R200/R200V)and final drive ratios. IMO expensive thru nengun but cheaper at jap auctions. btw US is also a good place to buy parts atm.
http://www.nismo.co.jp/en/products/competi...lsd/gt_lsd.html
Edited by dirtyRS4
Going by Jason's handy chart it looks as though most Stageas are 4.083 apart from the manual S2 so if that's what you've got then its a 4.111 viscous lsd - wrong ratio and viscous aren't all that flash either. However if you are happy with the viscous diff then you will need to change front and rear. At least that way if the rear lsd packs up you can get a GTR one (also 4.111) - or other aftermarket lsd - and the front will still be right
Thanks guys
I have just bought the S as a runabout as the current Stagea is no longer a "town car" and I need an estate
A vicous lsd would be an improvement for sure and as its pretty easy to swop and I have both cars I was simply going to swop the rerar diffs over (as long as compatible)
Looks like the diffs are different after all so changing both difffs on both cars is a no no , I will just have to carry on lokin for an lsd for the series 1.
Trouble is finding one in the uk is almost impossible .
Thanks guys
Try ebay - there are some Japanese people advertise there or posibly ebay.au - quite a bit of RB stuff.
So you have the stagea diff/sump on the 26? need to know what your front diff is first then we can advise you of the options
It has standard Series 1 RS Four diffs.
Re the standing 1/4.
Well I said I would post the time so even though it was not what I hoped ...........However this was entirely due to my rubbish driving
It was my first ever attempt on a strip which was pretty obvious Time was 13.09 with a crap start (0-60 ft was 2.5 sec ) And then to make things worse I missed forth gear completely
At 1000ft speed was 106 I missed gear and and went over the line in neutral at 104 mph
so no doubt that the car is very much quicker than me !
My car use to be series 2 auto
I now run a series 2 S manual rear end
According to the nismo chart I have 4.083 in the front and 4.111 in the rear
That's correct. In that case I guess I was mistaken to suggest that the OP has the "wrong ratio" and in fact it will be near enough. According to my calculator that is just over half of one percent difference so I guess the Attessa is capable of overlooking that small difference and the OP will be fine with putting that diff in the rear only.
In my case I have an R33GTR diff to go in the back and i will put one in the front as well because the motor is out anyway and RB26 front diffs are a dime a dozen because people put RB26s into two wheel drive cars all the time.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
