Gday lads, thought id give a quick report on how i went with this mix
So methanol was $260 205l drum, bp98 $1.?? a litre. and with e85 costing us $550 for 205l here in perth i thought it would be worthwhile giving this ago.
result was 560hp at 21pounds and we ran out of fuel system, as an idea we ran 527 at the same boost level.. but the methanol mix picked up through the middle
would i do the methanol mix again.. probably not, will just finish of this drum and will be trying e85 next
and just so you guys know methanol is poisonous and corrosive it is illegal to be used on the street, even mixed with the petrol it is a very strong methanol smell when burning
details on the build
R32 GTR
ENGINE
built engine
stage 2 hks 272 cams
hks cam gears
TO4Z Garrett
6 boost
48mm turbo smart gate
twin z32 afms
fuel system
sx fuel pump,surge tank,-8 lines
1450 fuel injector clinic
sard reg
https://www.sau.com.au/forums/topic/338301-methbp98-mix/
Why did you go Methanol instead of Ethanol?
I can not see any advantages...
was sittin with a good mate that runs methanol in his burnout car and after a few discussions and some research we thought we'd give it a go..
plenty of positives for it lad(e85 in perth is $2.68 per litre my methanol/petrol mix worked out at $1.35 a litre half the price and just as much power potential), unfortunately for me it didnt go as planned, i underestimated the fuel system required.at a guess if i ran another sx pump and some id2000's i have no doubt we would be seeing over 650.BUT i am pretty sure if i run e85 with the same setup i have now i will have the same issue with not enough fuel system..
e85 50% 50% bp like you have used is probably what i will try next, if it doesnt perform the way i want i will upgrade the fuel system too a monster setup
my setup is methanol safe ie. i run a seperate fuel cell in the boot, all lines are teflon, pumps are meth safe, injectors are meth safe. and also this car is not a street car, it isnt even licensed, i would not suggest for anyone to use this type of mix if they were planning on driving it daily or were not prepared to flush the system and store the fuel correctly.
https://www.sau.com.au/forums/topic/338301-methbp98-mix/#findComment-5467761
Ran this tune around the track at powercruise for the weekend.. very impressed, feels much stronger through the whole rev range compared to my pump tune.
anyone ever done this mix and successfully made power? any fuel system guru's that could tell me what i need to upgrade to reach my 26-27 psi boost level?
or could the methanol be reduced and the bp increased? what sort of effect on octane does this have?
will still be giving e85 a shot but just curious to give this another crack too..
https://www.sau.com.au/forums/topic/338301-methbp98-mix/#findComment-5480834
the engine bay wiring was the least of my worries tryin to get that car to powercruise man :thumbsup: haha we were still adding terminals to the main battery terminal on saturday morning!! mostly fuel system sh*t, that will eventually be hidden to a junction box somewhere.. yeah was lookin for ya on the cruises, but we were never on the same cruise eh.. saw brockas in my mirror once coming down to the main straight and was hopin for a run.. but he wouldnt come play!! he may have been leavin track or something.. anywayssss
e85 will happen.... but i have a drum of methanol i have to do something with :D
https://www.sau.com.au/forums/topic/338301-methbp98-mix/#findComment-5480901
http://www.skylinesaustralia.com/forums/E8...80&start=80
old news but is a alternative for E85 if you cant get it somewhere.
yeah been following that thread too trent!
Its a convenience thing for me aswell, for example last weekend i was at powercruise here in perth and camped up with some of my v8 mates who run on methanol, so there was plently of methanol to go round..
at the end of the day, i dont drive this car on the street.. and its as simple as undoing and switching two -8 fuel fittings from cell to main fuel tank and flushing with pump 98.. for long term storage.
another thing people may be interested in.. after running 180litres of this mix, my oil is still fine.. i was concerned about it milking up but have had no issues YET.
https://www.sau.com.au/forums/topic/338301-methbp98-mix/#findComment-5481859
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
