Gday lads, thought id give a quick report on how i went with this mix
So methanol was $260 205l drum, bp98 $1.?? a litre. and with e85 costing us $550 for 205l here in perth i thought it would be worthwhile giving this ago.
result was 560hp at 21pounds and we ran out of fuel system, as an idea we ran 527 at the same boost level.. but the methanol mix picked up through the middle
would i do the methanol mix again.. probably not, will just finish of this drum and will be trying e85 next
and just so you guys know methanol is poisonous and corrosive it is illegal to be used on the street, even mixed with the petrol it is a very strong methanol smell when burning
details on the build
R32 GTR
ENGINE
built engine
stage 2 hks 272 cams
hks cam gears
TO4Z Garrett
6 boost
48mm turbo smart gate
twin z32 afms
fuel system
sx fuel pump,surge tank,-8 lines
1450 fuel injector clinic
sard reg
https://www.sau.com.au/forums/topic/338301-methbp98-mix/
Why did you go Methanol instead of Ethanol?
I can not see any advantages...
was sittin with a good mate that runs methanol in his burnout car and after a few discussions and some research we thought we'd give it a go..
plenty of positives for it lad(e85 in perth is $2.68 per litre my methanol/petrol mix worked out at $1.35 a litre half the price and just as much power potential), unfortunately for me it didnt go as planned, i underestimated the fuel system required.at a guess if i ran another sx pump and some id2000's i have no doubt we would be seeing over 650.BUT i am pretty sure if i run e85 with the same setup i have now i will have the same issue with not enough fuel system..
e85 50% 50% bp like you have used is probably what i will try next, if it doesnt perform the way i want i will upgrade the fuel system too a monster setup
my setup is methanol safe ie. i run a seperate fuel cell in the boot, all lines are teflon, pumps are meth safe, injectors are meth safe. and also this car is not a street car, it isnt even licensed, i would not suggest for anyone to use this type of mix if they were planning on driving it daily or were not prepared to flush the system and store the fuel correctly.
https://www.sau.com.au/forums/topic/338301-methbp98-mix/#findComment-5467761
Ran this tune around the track at powercruise for the weekend.. very impressed, feels much stronger through the whole rev range compared to my pump tune.
anyone ever done this mix and successfully made power? any fuel system guru's that could tell me what i need to upgrade to reach my 26-27 psi boost level?
or could the methanol be reduced and the bp increased? what sort of effect on octane does this have?
will still be giving e85 a shot but just curious to give this another crack too..
https://www.sau.com.au/forums/topic/338301-methbp98-mix/#findComment-5480834
the engine bay wiring was the least of my worries tryin to get that car to powercruise man :thumbsup: haha we were still adding terminals to the main battery terminal on saturday morning!! mostly fuel system sh*t, that will eventually be hidden to a junction box somewhere.. yeah was lookin for ya on the cruises, but we were never on the same cruise eh.. saw brockas in my mirror once coming down to the main straight and was hopin for a run.. but he wouldnt come play!! he may have been leavin track or something.. anywayssss
e85 will happen.... but i have a drum of methanol i have to do something with :D
https://www.sau.com.au/forums/topic/338301-methbp98-mix/#findComment-5480901
http://www.skylinesaustralia.com/forums/E8...80&start=80
old news but is a alternative for E85 if you cant get it somewhere.
yeah been following that thread too trent!
Its a convenience thing for me aswell, for example last weekend i was at powercruise here in perth and camped up with some of my v8 mates who run on methanol, so there was plently of methanol to go round..
at the end of the day, i dont drive this car on the street.. and its as simple as undoing and switching two -8 fuel fittings from cell to main fuel tank and flushing with pump 98.. for long term storage.
another thing people may be interested in.. after running 180litres of this mix, my oil is still fine.. i was concerned about it milking up but have had no issues YET.
https://www.sau.com.au/forums/topic/338301-methbp98-mix/#findComment-5481859
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
