Has anyone read the new Motor Magazine Hot Tuner battle? I'm actually quite surprised that the VW Golf Cars were quick around the track then the Evo's/Sti's..
Eastern Creek - Warren Luff
APR Golf R - 1min 59sec [$34,100 in modifications] - 230awkw
APR Golf Gti - 2min 0.06 sec [$24,395 in modifications] - 217 awkw
TMR Evo X - 2min 2sec [$12,451 in modifications] - 196 awkw
MRT STI - 2min 3.04sec [$49,528 in modifications] - 271 awkw
MRT EVO X- 2min 6.04sec [$22,687 in modifications] - 226awkw
There are alot of other cars in there and appears to be quite an interesting read.
Just woulda thought the Evo's/Sti's would have spanked the Golf cars around a track...
https://www.sau.com.au/forums/topic/338309-motor-hot-tuner-challenge/
  • Replies 53
Yeah i was having a read about that, but i think you will find some of the cars had very different rubber on thats why the times are all over the place.
maybe the Jap group was done in the wet and the euros were in the dry...
i was just amazed at how overpriced the mods were, esp the exhaust systems!
interesting... isn't the Golf Gti FWD though?
did they all run a control tyre?
not a good ad for MRT lol
Sorry typo. yes you are correct fwkw
There is no control tyre every car is different. i.e.
APR Golf R - Hankook Ventus
APR Golf Gti - Hankook Ventus
TMR Evo X - Dunlop Direzza 03G
MRT STI - Bridgstone Re55S
MRT EVO X- Bridgstone Re55S
Also FYI 1/4 mile times:
APR Golf R - 13.28 secs
APR Golf Gti - 13.72secs
TMR Evo X - 13.37secs
MRT STI - 12.33secs
MRT EVO X- 13.06 secs
LOL an Evo with 20k sunk into it only made 220awkw?
You can do that on the factory turbo & ECU. I doubt the figures quoted half the time
Motor "tuner challenge" is a load of crap, always has been.
Just have a look @ last years or the years before with the R35's. They picked the most sedately modified GTR in Australia compared to 350rwkw+ HSV's which obviously are highly modded.
There were PLENTY of workshops with signifigantly more powerful/sorted cars.
The bta F6 had shit tyres apparently, it was the most powerful but couldnt put it to the ground. Was a pretty shit read, as was said times were all over, the only control was BP fuel.. should have had to have a control tyre as well.
Some of the track laps where done in the wet, doesnt specify which ones where done in the dry and which ones where in the wet so I guess its not much of a comparison :laugh:
This sums it up exactly. Nothing set even remotely the same. Stick the front wheel drive golf on a wet track then put any of the AWD cars on the same track dry and they will kill them. It's a waste of time.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
