First thing, I know you probably read the title and said "time to go tell some noob he's gay!"
Please don't, Im 18 and im going through the phase where I like the idea of interior neons, not over the top, but i do like a little illumination.
I used to have neons on my old Laser, but they were the ones that use cig lighter adapters, I don't like that idea and I don't wanna ruin my completely factory standard Skyline by hard wiring.
Anybody know of any ideas for interior illumination with a battery supply? Like a light with its own battery that I can replace that will just stick somewhere inside the cabin, LED or neon, i don't mind, but I want it to be self sufficient, so there's no running cabling to ruin my skyline's clean look if I decide to take it out.
Any help appreciated.
https://www.sau.com.au/forums/topic/338370-neon-lights/
  • Replies 80
Hey mate,
I have 2 blue L.E.D neons under either side of my dash, They look really good, nice touch to the car,
What i did, is a run a power wire from the positive terminal of the batter, and install a switch in your car, and connect it all up,
My battery has never drained,
But last week i changed it to this:
i got the power wire and connected it to my Speedo lights dimmer, now it comes on with my lights, but its still connected to the switch, so i can still turn it off or on whenever i want too,
I have blue dash lights, Number plate lights, neons, so it all looks matched :/
heres a picture, not mine, but very similar, Looks nice. When you buy them, cut of the cigarette charger part
Good luck :P
https://www.sau.com.au/forums/topic/338370-neon-lights/#findComment-5468539
you got a accessories running from the back of ur ciggi lighter its a orange wire on the 33's not sure about ur 34, wire it to that so when you turn ur car on they come on make sure you dont cut the transformer off the neons as you will f**k them up... i got 2 black light neons running under my dash similar to the blue ones in the pic posted they illuminate white products and look unreal
:/ up for the neons chicks love them!
https://www.sau.com.au/forums/topic/338370-neon-lights/#findComment-5468798
didnt realize you guys write the rules on what people can do to there car !!! best you write a thred on what we can and can do to our car so that at the next meet i dont upset you with an unacceptable mod !!! call me gay and you might loose a few teeth !!!.
i have neons !!! and there not for the rice factor i have a 9 year old brother and my wifes frind has 3 kids under 11 and they love it (the youngest sees a skyline and instantly yells out "loooook its bryan" , we all do things for different reasons and tastes dont hate on people because there different thats why theres so much violence and racism in this country because if we all dont love justin beber like you fags then we must be gay !!!!
https://www.sau.com.au/forums/topic/338370-neon-lights/#findComment-5470152
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
