ENGINE SOLD, this is a complete car minus engine and turbo kit (loom everything is still in the car), RB26 will drop in. Car is currently registered. If someone buys it and wants it tuned i will happily tune it for free once the engine is fitted (2 hr job as front is setup for quick instal and removal)
Car has:
New Greddy coil-overs (setup for rb) have original springs too.
Full Nismo Arm kit (front and rear lower arms, all new)
Zenith guard bracing (extensive chassis strengthener)
rebuilt steering rack
Adjustable toe arms
Uras castor rods
Uras extra lock tie rods and spacers
Super Now tie rod ends
Nismo 2way new
R32 GTR cradle
5 bolt shafts not the weak 6 bolt
Str8 thru exhaust with twin rear bozuku flutes
oil cooler kit
Greddy 115mm intercooler ($2500 new)
Greddy radiator (r33 gtr) 1000 new
tomei fuel pump (sold)
Powerfc d-jetro andc all sensors and RB26 loom (just slip in a engine)
R34 GTT box bought with 17000kms
BLITZ twin plate (top of the range ORC)
new tailshaft
R32 gtr rear brakes
r33 front brakes
Blitz MR3 pads ($350 for each end)
whiteline sway bars adjustable front and rear
half cage suit sunroof
drift tacho and oil temp, oil press, water temp gauges
nardi steering wheel
vertical hydraulic handbrake with booster for one finger actuation (std still in place and working)
drift kevlar passenger seat
Bride zeta seat (perfect)
50mm over fenders rear
17x9 +15 uras ns02 all round with new toyo proxes 4 tyres
full uras bodykit genuine
High Uras GT wing
Uras clear tailights
HID headlights
Genuine c-west bonnet
much much more all for $15k or will split over the next few weeks
  • 3 weeks later...
Did the S13 sell Trent or are you spliting it up?
This is a super well setup machine! Hope i can get some bits from it?
oh man. so tempted to buy this too. I have a stock RB26 out of my 94 model R32 in perfect condition. could have it on the road pretty cheaply. damn you trent. if I could sell the last silvia I bought off you quickly I'd buy this in a heart beat.
BTW, sad to see you selling. hopefully something new on the cards for Cat?
for anyone else considering this car. it's a steal for $15K. at around $5K for a used RB26 or $10K-$15K for something special you would have a top level RB S13 for $20K or so. in fact the ultimate plan would be buy this car, and buy my Prime Garage Nur engine and bolt the two together. :)
http://www.skylinesaustralia.com/forums/Pa...28#entry5520028
all coming apart this weekend
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
