Hi guys!!
My GT-R is idling at 1050 rpm. Already cleaned the AAC valve before, butterflies were also checked... the car runs fine though. It's just the idle that keeps me wondering.
So GT-R gurus, is it just fine or there is something wrong w/ it? :/
Thanks in advance guys!
Edited by GodziRRa
https://www.sau.com.au/forums/topic/338405-gt-r-idle/
My mate has a bit of poly pipe made up with a compressor attachment and hooks it up befor the intercooler and pushes compressed air into the plenum via the intercooler.
start psi low and move it up to around 20 psi you will find any leaks at all if they are there.Keep a spray bottle with water handy and a peice of hollow pipe to listen threw :).
motor off of coarse.
https://www.sau.com.au/forums/topic/338405-gt-r-idle/#findComment-5470768
start psi low and move it up to around 20 psi you will find any leaks at all if they are there.Keep a spray bottle with water handy and a peice of hollow pipe to listen threw ;) .
Sounds like a lot of work. :D
https://www.sau.com.au/forums/topic/338405-gt-r-idle/#findComment-5473004
The ECU needs to be put into base-idle mode or else when you adjust that screw the ECU will just compensate.
Moo - is that info from the shop manual? My memory is that you unplug the electric connector to the AAC to stop the compensation, then adjust the idle to where you want it, then reconnect.
https://www.sau.com.au/forums/topic/338405-gt-r-idle/#findComment-5475677
another cheating way of adjusting idle is to have car warmed up, then watch AAC on consult and turn idle screw until its around 20-25. so depending if the AAC starts at ~20 (then u turn it until AAC starts to go up, then stop) or if it starts high (e.g. 40+) then you're turning it so AAC goes down until it stops going down. but this is when the car is running normally and just having minor issues, if there is something else causing high idle then this might not work.
e.g. i used to have warm start stalls due to AAC being too high (40-50) as idle was set too low and not having enough room to catch falling idle.
https://www.sau.com.au/forums/topic/338405-gt-r-idle/#findComment-5476146
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
