Hey guys my car was in an accident so looks like these are no longer going on to her :laugh:
1. Tomei Fuel pressure regulator Brand new i'll throw in the rail adaptor
$135
2.RB25det Cam covers Polished set
$150
3. 600x300x76 Intercooler painted black
$80
4. Garrett GT3076R turbo anti surge front .63 ex gate rear
$1650
5. HKS low mount cast manifold T3 flange with spot for external gate
$550
6. Turbosmart 38mm (red) External gate Brand new in the box with all springs etc
$350
7. Koni Yellow shocks (similar to bilstien) x4 aajustible fronts
$350
8. Whiteline rear springs brand new fitted and test run before being removed
$100
9. Brand new Gasket set rocker covers
$80
10. Hybrid Front mount intercooler 450x300x76
$150
11. GTR radiator with twin thermo fans was in good working order before being removed for upgrade
$100
12. Ross tuff bond harmonic balencer in excellent condition
$450
13. RDA Slotted rottors Rear Brand new in the box never used
$180
14. Bendix Heady duty rear brake pads new in the box
$75
15. AEM trueboost controller electronic boost controller new taken out of the box and looked at :D
$360
Post or PM guys all items located in Newcastle
Edited by lookingforboost
Hey just intrested in the shocks and white line springs.. How old are the shocks and are the spring standard height.. Got front springs too ?.. Thanx
Hi i bought them off an other user and didnt get to put them into my car they were supposed to be only a few weeks old. the springs are i think 30 or 40mm lower, no front springs sorry.
pics of the cam covers?
i'll Put pics up today :)
which car did the shocks & springs come out of ?
sorry they were from an R33 GTST
GARRETT 3076R ON HOLD / SOLD PENDING PAYMENT
Hey guys my car was in an accident so looks like these are no longer going on to her ;)
$135
$150
$80
$1650
$550
$350
$350
$100
$80
$150
$100
$450
$180
$75
15. AEM trueboost controller electronic boost controller new taken out of the box and looked at :(
$360
find out what postage to mackay 4740 is for the rocker covers and consider them sold!!! can you send pics of them to 0431734380 thanks :D
hey keen for the brakes.. new to this so not shure how it works but i will take the brake disks and pads off ya for a clean $150
and where are you located?
  • 4 weeks later...
Hey buddy, im interested in the tomei fpr....is it a genuine one? where did you buy it from?
Price delivered to 2567
Aiden
Cheers...
Hey Aiden,
He is around here somewhere, i'll find him and get him to reply... I am pretty certain its genuine...
Postage will cost you around $10-15
Hey thanks matt.... I work with him guys I was hidding in a container lol yes its genuine $5 postage on the reg no adapter though as I have no more nissan ones left
Ross balencer Sold
Ryan will you REPLY TO PM ,cheer`s Chuckie.
Whats the question and i'll ask him if i see him for ya (PM me man) :P
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
