Hey guys my car was in an accident so looks like these are no longer going on to her :laugh:
1. Tomei Fuel pressure regulator Brand new i'll throw in the rail adaptor
$135
2.RB25det Cam covers Polished set
$150
3. 600x300x76 Intercooler painted black
$80
4. Garrett GT3076R turbo anti surge front .63 ex gate rear
$1650
5. HKS low mount cast manifold T3 flange with spot for external gate
$550
6. Turbosmart 38mm (red) External gate Brand new in the box with all springs etc
$350
7. Koni Yellow shocks (similar to bilstien) x4 aajustible fronts
$350
8. Whiteline rear springs brand new fitted and test run before being removed
$100
9. Brand new Gasket set rocker covers
$80
10. Hybrid Front mount intercooler 450x300x76
$150
11. GTR radiator with twin thermo fans was in good working order before being removed for upgrade
$100
12. Ross tuff bond harmonic balencer in excellent condition
$450
13. RDA Slotted rottors Rear Brand new in the box never used
$180
14. Bendix Heady duty rear brake pads new in the box
$75
15. AEM trueboost controller electronic boost controller new taken out of the box and looked at :D
$360
Post or PM guys all items located in Newcastle
Edited by lookingforboost
Hey just intrested in the shocks and white line springs.. How old are the shocks and are the spring standard height.. Got front springs too ?.. Thanx
Hi i bought them off an other user and didnt get to put them into my car they were supposed to be only a few weeks old. the springs are i think 30 or 40mm lower, no front springs sorry.
pics of the cam covers?
i'll Put pics up today :)
which car did the shocks & springs come out of ?
sorry they were from an R33 GTST
GARRETT 3076R ON HOLD / SOLD PENDING PAYMENT
Hey guys my car was in an accident so looks like these are no longer going on to her ;)
$135
$150
$80
$1650
$550
$350
$350
$100
$80
$150
$100
$450
$180
$75
15. AEM trueboost controller electronic boost controller new taken out of the box and looked at :(
$360
find out what postage to mackay 4740 is for the rocker covers and consider them sold!!! can you send pics of them to 0431734380 thanks :D
hey keen for the brakes.. new to this so not shure how it works but i will take the brake disks and pads off ya for a clean $150
and where are you located?
  • 4 weeks later...
Hey buddy, im interested in the tomei fpr....is it a genuine one? where did you buy it from?
Price delivered to 2567
Aiden
Cheers...
Hey Aiden,
He is around here somewhere, i'll find him and get him to reply... I am pretty certain its genuine...
Postage will cost you around $10-15
Hey thanks matt.... I work with him guys I was hidding in a container lol yes its genuine $5 postage on the reg no adapter though as I have no more nissan ones left
Ross balencer Sold
Ryan will you REPLY TO PM ,cheer`s Chuckie.
Whats the question and i'll ask him if i see him for ya (PM me man) :P
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
