Ever since I purchased my R33 GTS-t way back in July 2007 I have been pondering why my car has the factory charcoal canister as well as an aftermarket item hooked up in series with it. Aftermarket item is located on the strut tower near the power steering fluid reservoir. After looking at many other Ricelines I have come to the conclusion that my Riceline appears to be the only one like this.
Why would another item be installed?
Should I remove the extra charcoal canister?
Should I leave it in so if I get asked to pop the bonnet I can say "Look! Two charcoal canisters! I care for the environment in my mid '90s turbocharged sports car 'n' shit! True story!"
I would supply pics, but being at work and the car being at home it isn't possible :laugh:
Personally, I don't think it needs to be there so I may remove it for the extra 200g weight reduction.
Thanks :D
Cass
EDIT
The plot thickens...
Found a (poor) photo of my engine bay on facebook
To me it looks like it is hooked up in parallel and not in series like I originally said...
https://www.sau.com.au/forums/topic/338442-two-charcoal-canisters/
One of my GTS-T's had the same thing with the factory and an aftermarket charcoal cannister installed.
I would suggest that it was part of compliance where they simply installed a new aftermarket unit instead of going to the trouble of proving that the original factory unit was still working correctly.
I have since removed the aftermarket unit with no adverse affects.
If that is the case it makes pretty good sense :wub:
Might take it off this weekend, I don't expect the car to change at all... the only time I have had issues with charcoal canisters is when the purge control solenoid on my old Subaru shat itself, essentially jamming it open so the canister was venting to the throttle body all the time... made it idle like a pig in summer :)
    • Probably being in IT for 2 decades, and spending my time documenting trees worth of shit and also being on the receiving end has taught me a thing or two.
    • Why's that depressing, wouldn't it be able to go indefinitely until the battery gets old and craps itself? If it's constantly on charge/maintaining charge, won't that keep the battery healthy?
    • One of my concerns initially was if something catches fire somehow.
    • I think I know what you mean. I saw the same thing a while back, I think either the images on the website were wrong or the model was slightly updated. It was weird when I first looked at it, same model but different looking unit.
    • At work we've got a smaller version of the Projecta that Duncan posted above. At home, I have an ALDI trickle charger. Ive had it for about 8 years now. Only issue with it, it's a smart charger, so if the battery is dead, it won't bring it up, but I have a variable power supply that I limit current on, and set to a max of 14.4v. once it starts charging up, I put the aldi unit on and remove the variable PSU. ALDI one will do 12v, or 6v, then has mode for "car" "motorbike", and "snow". With car or motorbike more for its internal workings, and snow is the trickle mode. I have a battery in the garage that lives on this charger for about the last 18 months now on Snow mode. When I need to charge my other batteries (eg, ones that have died in a car), I get them started and then run it on car mode. Voltage is always sitting really nice, and hasn't killed a battery yet. that charger isn't good for things like Lithium batteries etc, I'd only use it on Lead Acid.
