Well the time has come it appears to pull the engine - mostly to do the upgrades but also to do my starter motor. We had the car up on the hoist yesterday and holy god is it a tangle of lines and hardware!
From those who have pulled these engines is there any major tricks to getting at things like the starter motor top bolt? Best accessible by taking the oil filter off and getting at it through there? Any hints/tips about the task as a whole would be greatly appreciated. I'm sure we'd get there in the end but having some hints would make like easier as its not exactly like pulling my 240z engine or mini engines... Mini engine out in 25 mins :blink: This will take much longer I fear...
https://www.sau.com.au/forums/topic/338454-pulling-rb26-from-bnr32/
Yer drop from the bottom. Its easier. All plumbing to the turbos will need to be removed so the engine can drop down in between the chassis rails. A couple of power steering lines will also need to be disconnected from the kframe.
Starter motor top bolt needs 14mm short socket, wobbly drive and extensions. Yes they are a pain to do but you can do it with the right tools.
Will the engine with the turbos and plenum attached fit through the chassis rails? Thats where I thought we'd get hung up... I did have a look at doing it this way but thought it would be a real tight squeeze / not fit through...
Took mine out/ and put it in always through the top, can't do much else in the driveway.
I have taken it out with the gearbox and without, now i tie the box to the roll cage and just push it back a bit leaving it in the car.
much easier to do if you pull turbos off. I can lend you the manual if you want too. I also have an attatchment for the crane which allows you to tilt easily but you lose a bit of height so depends on the crane.
If you drop the gearbox crossmember and tilt the engine back you can more easily get at the starter bolts, i just did it with a ring spanner. Just watch the dumps on the other side
Cheers Jeff. Thanks for the offer of tools but I think i'll have that one covered - might hit you up for the manual though :P Is yours electronic or hardcopy?
Confirms a few things. I want to pull the box anyway to fix a couple of noisy bearings in it so should be a good time had by all on the day its coming out. Now re-booked in for the 11th Oct. Just after the cruise... Might need a hand clutch starting the bugger if it doesnt work on the day :blink:
ive pulled 3 out, one with the gearbox attached,
took around 3 hours.
have to take out the driver CV joint and it just likes to catch on the metal lines above it,prise it off. thats all!
make sure you undo both nuts on the engine mounts (found this easier)
i just undid the front pipes, had no issues with the turbos with dumps still connected.
God bless my HR31 engine bay, no ABS etc room amore :happy:
Its funny you know - I always looked at the engine in the car and went "The Japs were awesome to build this and fit it all in..." Now I look at it and curse!
With my 70 Cooper S I can get the engine out in 20-30mins and 30-40 back in and running. This will be a nightmare comparitively. Swapsies?
Oh it still takes me just as long - i have issues with RB25 gearbox in a HR31 shell so it's gotta be dropped from the bottom...
Still a cvnt load easier.
But yes, definately easier to go from the bottom IMO.
It can be done from the top as well though, just more time consuming and careful leaverage when the motor is on the crane to get it over the rad support etc.
we used to do all of them by dropping it down, far easier and quicker. Think i have some pics somewhere. Becomes a 2hr operation instead of a 3-4hr head fck.
Thanks Trent. Some pics would be great. More info I have before I drop it, better it will go.... Can't wait to throw the goodies i've bought on!
what issues? sure the tunnell cops a bit of a beating but it comes out the top easily enough
I bet you don't have a fully seam welded engined bay thats been filled & painted in most area's :P
Gotta be veeeery careful :happy:
Ive done both ways and I reckon top out is better.
Sure it comes out the bottom way in 2 hours BUT then you gotta remove the engine and box off of the k frame, put k frame back in to get the car mobile, disconnect suspensions etc etc. I know you have to do at least the drivers side, but still....
Once you get the intake piping and cooler piping and radiator out, theres plenty of room.
Drop the box xmember down to get the top bellhousing bolts then put it back up.
A ratchet spanner is your friend for the top starter bolt.
Each to their own.
Try both ways...good practice :happy:
I bet you don't have a fully seam welded engined bay thats been filled & painted in most area's :wub:
Gotta be veeeery careful :)
yer that wouldnt help
white engine bay with lots of black decoration (grime n shit) makes it easier not to care :)
drop sub frame down to the last threads on the bolts
put the driverside shaft out
reef it out the top 3 hours tops with two poeple( will take longer if you have not dont the top gearbox bolts before or the starter motor before)
if you have a hoist straight out the bottom maybe 2 hours
you dont need to pull the turbo either way (that is massive waste of time and 40 times easier to do when the engine is out)
lol.. pull turbos off... lol
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
