Well the time has come it appears to pull the engine - mostly to do the upgrades but also to do my starter motor. We had the car up on the hoist yesterday and holy god is it a tangle of lines and hardware!
From those who have pulled these engines is there any major tricks to getting at things like the starter motor top bolt? Best accessible by taking the oil filter off and getting at it through there? Any hints/tips about the task as a whole would be greatly appreciated. I'm sure we'd get there in the end but having some hints would make like easier as its not exactly like pulling my 240z engine or mini engines... Mini engine out in 25 mins :blink: This will take much longer I fear...
https://www.sau.com.au/forums/topic/338454-pulling-rb26-from-bnr32/
Yer drop from the bottom. Its easier. All plumbing to the turbos will need to be removed so the engine can drop down in between the chassis rails. A couple of power steering lines will also need to be disconnected from the kframe.
Starter motor top bolt needs 14mm short socket, wobbly drive and extensions. Yes they are a pain to do but you can do it with the right tools.
Will the engine with the turbos and plenum attached fit through the chassis rails? Thats where I thought we'd get hung up... I did have a look at doing it this way but thought it would be a real tight squeeze / not fit through...
Took mine out/ and put it in always through the top, can't do much else in the driveway.
I have taken it out with the gearbox and without, now i tie the box to the roll cage and just push it back a bit leaving it in the car.
much easier to do if you pull turbos off. I can lend you the manual if you want too. I also have an attatchment for the crane which allows you to tilt easily but you lose a bit of height so depends on the crane.
If you drop the gearbox crossmember and tilt the engine back you can more easily get at the starter bolts, i just did it with a ring spanner. Just watch the dumps on the other side
Cheers Jeff. Thanks for the offer of tools but I think i'll have that one covered - might hit you up for the manual though :P Is yours electronic or hardcopy?
Confirms a few things. I want to pull the box anyway to fix a couple of noisy bearings in it so should be a good time had by all on the day its coming out. Now re-booked in for the 11th Oct. Just after the cruise... Might need a hand clutch starting the bugger if it doesnt work on the day :blink:
ive pulled 3 out, one with the gearbox attached,
took around 3 hours.
have to take out the driver CV joint and it just likes to catch on the metal lines above it,prise it off. thats all!
make sure you undo both nuts on the engine mounts (found this easier)
i just undid the front pipes, had no issues with the turbos with dumps still connected.
God bless my HR31 engine bay, no ABS etc room amore :happy:
Its funny you know - I always looked at the engine in the car and went "The Japs were awesome to build this and fit it all in..." Now I look at it and curse!
With my 70 Cooper S I can get the engine out in 20-30mins and 30-40 back in and running. This will be a nightmare comparitively. Swapsies?
Oh it still takes me just as long - i have issues with RB25 gearbox in a HR31 shell so it's gotta be dropped from the bottom...
Still a cvnt load easier.
But yes, definately easier to go from the bottom IMO.
It can be done from the top as well though, just more time consuming and careful leaverage when the motor is on the crane to get it over the rad support etc.
we used to do all of them by dropping it down, far easier and quicker. Think i have some pics somewhere. Becomes a 2hr operation instead of a 3-4hr head fck.
Thanks Trent. Some pics would be great. More info I have before I drop it, better it will go.... Can't wait to throw the goodies i've bought on!
what issues? sure the tunnell cops a bit of a beating but it comes out the top easily enough
I bet you don't have a fully seam welded engined bay thats been filled & painted in most area's :P
Gotta be veeeery careful :happy:
Ive done both ways and I reckon top out is better.
Sure it comes out the bottom way in 2 hours BUT then you gotta remove the engine and box off of the k frame, put k frame back in to get the car mobile, disconnect suspensions etc etc. I know you have to do at least the drivers side, but still....
Once you get the intake piping and cooler piping and radiator out, theres plenty of room.
Drop the box xmember down to get the top bellhousing bolts then put it back up.
A ratchet spanner is your friend for the top starter bolt.
Each to their own.
Try both ways...good practice :happy:
I bet you don't have a fully seam welded engined bay thats been filled & painted in most area's :wub:
Gotta be veeeery careful :)
yer that wouldnt help
white engine bay with lots of black decoration (grime n shit) makes it easier not to care :)
drop sub frame down to the last threads on the bolts
put the driverside shaft out
reef it out the top 3 hours tops with two poeple( will take longer if you have not dont the top gearbox bolts before or the starter motor before)
if you have a hoist straight out the bottom maybe 2 hours
you dont need to pull the turbo either way (that is massive waste of time and 40 times easier to do when the engine is out)
lol.. pull turbos off... lol
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
