Hey guys,
Ok, story so far: My r34 gtt (pull type clutch) went in for a clutch change, the mechanic took everything bar the gearbox off, and that's where we're up to. We CANNOT get the gearbox off. We've tried using crowbars and what happens is the gearbox moves away from the engine before snapping back on to it.
The mechanic reckons it's the clutch and pressure plate grabbing and that the only solution now is to cut a hole in the bottom of the gearbox to get at the pressure plate screws.
Does this sound normal? Surely this isn't a rare problem with these cars?
Thanks in advance
Edited by Galois
https://www.sau.com.au/forums/topic/338455-help-gearbox-stuck/
Hey guys,
Thanks in advance
Sounds like he hasnt unclipped the release bearing.
Here is the DIY:
http://www.skylinesaustralia.com/forums/R3...Gu-t268118.html
He hadn't, but by the time I got there he'd already sawed the hole and was undoing the pressure plate. Not sure how he plans to put it all together without undoing that clip though, I guess he'll figure it out.
The flywheel bearing was fkd too, as well as the uni-joints and center bearing, which have to be replaced. This has been such a mission.
OUCH i would be so dirty. ive just got images running through my head of this guy with his arm reaching through this big ass hole saying its gonna cost more than quoted cos its such a nightmare job.
Cheers for the condolences. Currently looking at calling the nrma and the automative traders thingy tomorrow, as well as some skyline expert mechanics tomorrow to figure out what the hell is going on, where I stand and what to do next (if you have any suggestions please let me know!).
Kinda upset about it to be honest, but as long as he doesn't charge me for all the fking around labour I guess I'll have to put it behind me...
yeah even if "the clutch and pressure plate were grabbing" you can still take the pivot out of the clutch fork to slip off the box. Make sure you don't get a bill and I would be asking him to provide a replacement bell housing too (making sure it's a pull clutch type). post up your progress
So... any ideas what I do now? He was pretty confrontational about it when I pointed out the r-clip and the clutch fork under the boot...
He was being confrontational because he has NO idea. Trying to hide his ignorance.
I called 4 specialist mechanics in Sydney this morning who were recommended in a sau nsw thread, and they were all shocked. One even said "he was just joking with you mate" before I told him he'd already sawed the hole. All I got was a shocked silence in response.
Fk I wish I'd just driven to a specialist and didn't have this problem. Where can I get a new bell housing?
I think you really need to get it out if that shop asap, if he wants to charge you for the work done up to the hole cutting bit then he should also then pay up for a replacement bell housing. I wouldn't be asking him to swap bellhousings over either. If he's not up for paying for a replacement bellhousing then I don't see why he should ask you to pay for his lack of expertise.
He's going to say the bell housing is still structurally sound, how do I get this investigated? I assume this will involve x-ray scanning. Is there potential for the original part to be welded back in or will that just be a bandaid?
I wouldn't actually expect him to front up with a new or replacement bellhousing but what he has done has devalued the car even if it is welded up, and it's something that shouldn't have been done to start with if he'd had any idea what to do. The next place you go should be able to advise you on this, depends on the size and location of the hole. I would get a quote from a wreckers for replacement bellhousing (and factor in labour to change it over) so you have an idea of possible cost he has unnecessarily incurred.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
