Ok guy's big part sale need these parts gone... asap as i want 2 make room for my s15 project.
1. s15 Dmax rear fenders 50mm $375
2. z32 Airflow meter and plug $250
3. Coustom surge tank and bosch 044 fuel pump with lines $450
4. Greddy turbo timer $100
5. Bride seat with r32 gtst seat rails $550
6. Haltech platinum 1000 and patch loom for s15 $1800
7. 53mm Koyo radiator $600
8. s14 re-mapped computer $250
9. Standard s15 computer $250
10. Motor, turbo, gearbox setup for sale $14,500
*Arias 40 thou over size forged pistons
*Arias Chrome moly rings
*Scat H-beam rods
*ACL race bearings (main and rods)
*ACL race bearings (thrust)
*Full genuine Nissan gasket set
*HKS multy layer metal head gasket 1.6mm
*HKS heavy duty valve springs
*HKS Camshafts step 3, 264 EX and 272 IN
*HKS adjustable cam gear inlet and exhaust
*Tomei solid lifters
*Tomei rocker stoppers
*Brand new Nissan rocker arms
*ARP mains
*ARP headstuds
*Trust TD06-25G 10cm turbo with polished front comp cover, fully rebuilt and balanced by ATS
*Custom high mount steam pipe manifold
*HKS external gate 48mm with screamer pipe
*Sard 850cc injectors and plugs
*Greddy inlet plenum
*Xtreme custom made GTR clutch to suit SR20 1600kgs solid centre with Moly flywheel
*RB25DET gearbox with custom bellhousing
*Head was faced, valve stems seals, acid dipped
*Block has been bored, faced, tunnel bored, crack tested, honed, acid dipped, crankshaft crack tested, timing chain cover machined to suit both all done by Chris Milton Engine Developments.
11. r32 gtst rolling shell with loads of suspension parts! $6,000
Suspension:
Ohlins Coilovers
Adj Castor Rods
Adj Upper Arms
Adj Whiteline swaybars
R33 Lower control arms
Offset rack spacers
NP Wonder knuckles
Solid Alloy steering Spacer
Rear Adj Camber arms
Solid mounted rear cradle
Hicas Lock bar installed and all hicas lines and pumps removed from the car
044 intank pump
Interior:
Hydraulic handbrake
5 point safety harness
Fire extinguisher
Trust boost gauge
Nismo 260k dash cluster
Body:
Monkey warehouse Uras body Kit
Standard r32 gtst rims not the 1's in the pic
12. Nissan 200sx s14 s1 $14,500
*Twin thermo fans
*Exedy heavy duty clutch and fly wheel
*Blitz pod filter
*s15 motor (110,000 kms)
*s15 6 speed
*s15 suspension
*s15 rear end diff, hubs axles ect.
Interior:
*Pioneer head unit
*6 inch pioneer speakers
*Velo race seat
*Fire extinguisher
Exterior:
*Full JDM Aero Kit
*Amazon Green(Standard)
*Rolled Front Guards
*Pumped/Lipped Rear Guards
*Removed Standard Wing
*Origin Front Clear Indicators
*Commo Spec Clear Guard Indicators
*Work Emotion XC8sF: 18x9.5 +20 R: 19x10 +20
If any1 wants 2 know anything just ask.
can also get more pics if needed, cheers dave
https://www.sau.com.au/forums/topic/338456-big-parts-sell/
  • 1 month later...
Price drop want this stuff gone open 2 offers.
1. s15 Dmax rear fenders 50mm $375 now $325
2. z32 Airflow meter and plug $250 now $220
3. Coustom surge tank and bosch 044 fuel pump with lines $450 now $375
4. Greddy turbo timer $100 now $80
5. Bride seat with r32 gtst seat rails $550 now $450
6. Haltech platinum 1000 and patch loom for s15 $1800 now $1650
7. 53mm Koyo radiator $600 now $500
8. s14 re-mapped computer $250 now $220
9. Standard s15 computer $250 now $220
10. Motor, turbo, gearbox setup for sale $14,500 now $13,500
*Scat H-beam rods
*ARP mains
*ARP headstuds
11. r32 gtst rolling shell with loads of suspension parts! $6,000 now $4,500
Suspension:
Ohlins Coilovers
Adj Castor Rods
Adj Upper Arms
Offset rack spacers
NP Wonder knuckles
044 intank pump
Interior:
Hydraulic handbrake
Fire extinguisher
Trust boost gauge
Body:
12. Nissan 200sx s14 s1 $14,500 now 13,000
*Twin thermo fans
*Blitz pod filter
*s15 6 speed
*s15 suspension
Interior:
*Pioneer head unit
*Velo race seat
*Fire extinguisher
Exterior:
*Full JDM Aero Kit
*r33 gtr rims not the 1 in the pic!
https://www.sau.com.au/forums/topic/338456-big-parts-sell/#findComment-5524291
What did you do with the running gear out of the r32 gtst?
Previous owner had "sold" that car to me a couple months back but reneged on the deal as obviously you must have offered more money.
https://www.sau.com.au/forums/topic/338456-big-parts-sell/#findComment-5524306
putting it in my project car. did you just want the motor gearbox ect.
https://www.sau.com.au/forums/topic/338456-big-parts-sell/#findComment-5524324
  • 4 weeks later...
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
