ok guys im looking for an ecu expert (or at least some one who can answer my question) for a bit of help with a project im considering to build.
what im wanting to know is how a stock ecu determines the timing advance on a rb20de/25de r32 ecu.
what sensors determines this or is it just the cas sensor?
Edited by Mad-Max
https://www.sau.com.au/forums/topic/338526-ecu-experts-i-need-your-help/
the crank angle sensor is what the ecu uses to determine what position the engine is at. the ecu then adjusts the timing around this based off TPS voltage, rpm and AFM voltage according to what settings it was originally mapped with. it will also take into account any readings from the knock sensors and also the temp sensor can play a part in this as well as it will alter the timing at different engine temps.
ok forget about the fuel side of things and forget about the temp/knock sensors for a few mins here. i understand how they effect the timing when they need to
basically what im wanting to know is if the stock r32 ecu can work as a stand alone ignition system (only ignition) when only using the cas input to the ecu.
will it still advance the timing when rpm's are in play without those sensors (no afm, no tps)
Edited by Mad-Max
As mad082 has said, the function of the cas is to tell the ecu where each piston is in the cycle. The ecu then uses inputs from other sensors to calculate when to fire the spark.
So, no, it can't be used as a standalone ignition system if it is using only the cas as an input.
and why not???????? id like some one to elaborate on this for me pls .... that doesnt really answer my question, try and think outside the box on this one....
i know the cas tells the ecu where each piston is in the cycle... inturn this signal that is sent to the ecu and lets the ecu know the rpm. and if the rpm of the engine determines the level of timing advance why would it need a afm/tps sensor to advance the timing surely it would have a base timing map it works from?
i always thought an afm/tps was more for the fuel side of things and only had a very slightly small impact on the timing
i know for a fact that with no afm and tps an rb25 will still idle with only a cas sensor and maintain base timing. trust me ive tryed but what i couldnt do was rev the engine and gauge the timing advance at the time
Edited by Mad-Max
the engine will idle, but it will use 15 degrees timing the whole way through the rev range. and without the AFM it will only rev to 2500rpm.
to go into a bit more depth i will post up an ecu map to explain it.
in this map you can see that there is a rpm scale down the bottom and a load scale across the top. the load scale can be calculated by either AFM, map sensor of TPS or a combination of them. without the load scale you would simply be using the first colum of the map. now in this case, at high rpm you would have the timing advanced by a massive amount, so it would be pinging it's arse off. however not all maps are like this one. some will have the first box of the column at high rpm only having 5 or 6 degrees, while at higher load it may actually be tuned for 20 or 30 degrees, so in that case you may be losing 10 or 20 degrees of timing. however by not having anything plugged in and just having it in base timing mode where it is locked at 15 degrees, you will be losing anywhere from about 10 degrees timing to 25 degrees timing, so it would be an absolute slug. even if you advance the timing via the CAS to get the base timing to 25 degrees, then there will be sections where you are still well under and places where you are still over. moral of the story, don't be cheap. get an aftermarket ecu
thanx very much for that answers it exactly for me .... im just sortin out what options i have .... im currently lookin at another option of a standalone ignition system that can be pre programmed ect and programmed via a hand held/fixed controler either that or a re-programmed eprom.
if any one can think of any options i could use keeping in mind i only want it for the ignition and not the fuel ... fuel is only a bonus
this map shows it a bit better. look at the timing at 4000rpm. the top box is at low load (so light throttle). the bottom box it wide open throttle. there is a timing difference 23 degrees. now without the ECU recieving any type of info about the load on the engine then it will be running 36 degrees when it should only be running 13, so it will be pinging it's arse off. you could pretty much garantee the engine to fail in a matter of a couple of weeks (of regular driving), if not sooner.
generally any aftermarket ecu will be able to control just the timing alone as long as you still provide it with a TPS signal or a vaccum line for a map sensor.
i've just spoken to my tuner mate and am going to link him to this thread, so he can give you some more info.
http://www.diyautotune.com/
http://nistune.com/
g`day mad max, i`m mad082`s tuner mate, these are two websites that you should look into, the megasquirt does do a stand alone
ignition ecu that can be run of a vn commodore map sensor to do your load and is cheap. the niztune on the other hand is a little dearer but has the abilaty to use all your stock sensors and you can just zero out all of the fuel settings in it, i myself have done this
with a straight lpg rb25det and it work fantasic.
hope this helps, gary, Gympie Mechanical & Dyno.
MSD-6AL is what you need...dont bother with trying to use EFI Stuff! the MSD, ICE, Accel etc gear is designed to be used with carburettors so they dont need TPS, and map/maf inputs, just program the ignition curve and and vacuum advance and away you go.
yea ive seen this units used befor but i have little knowledge about them are they easily tuned and what can be done with them?? how are they tuned??
http://nistune.com/
ahh good yea a map sensor i thought about that didnt think id need to use one tho.... and the megasquirt unit was what i was lookin at ealier
--> ( http://www.trademe.co.nz/Browse/Listing.aspx?id=321916315 ).
its compatable with knock sensor (which i want to run) and map sensor plus i like the fact i can plug it into a laptop and have a fiddle :( and since im using a series 2 vct head that would be very handy for controlling it
the other one i had a glance at was the silicone chip kitset from JayCar but i thought it might be a bit sketchy
any thoughts/ideas much apprieciated guys
Edited by Mad-Max
the 6al's are tuned the same way as most efi computers, plug the laptop in and away you go, they also come with half a dozen or thereabouts preset curves if you dont want/cant get to a dyno
oh wow thats good ...do they run ok with a cas? and can they be used with a knock sensor or is aknock sensor a bit obsolete with these?
They are designed for use with distributors, not individual coils, no knock control or anything like that.
what motor is it going on?
so it wont work with a cas sensor and wasted spark setup?
a non turbo rb30/25 vct hybrid
Edited by Mad-Max
Ill have a looksy in the msd manual I have floating around somewhere, Might have something in it.
oh wicked :thumbsup: i was looking at them to start with but i thought they were only for dizzys lol
the more info the better :D haha i couldnt find out much about them when i looked
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
