Hey guys im looking into buying an R34 which has a stock turbo. However im also looking into buying an aftermarket turbo as time goes on,but im worried about getting defected by the police for aftermarket turbos. Is there any way that i could legally install an after market turbo kit and have no problems with the police.
thanx in advance guys
Bryce
https://www.sau.com.au/forums/topic/338540-after-market-turbos-and-defects/
I'm a little confused on this one, are you looking at just swapping out the old turbo for a new one. Or changing it from a single to twin?
If it's just a swap, you really shouldn't have any problem unless it's an illegal turbo in the first place, failing that, just rework the piping to hide the turbo 'under' the engine. Unless you get an Officer whose looking to bust your balls, they're not going to get on all fours to look under the car and risk getting their uniform dirty.
None of my friends have been done for their AMarket turbo's in their car and my old WRX was never done for that either.
The other trick, have something in the engine bay that stands out that could be considered illegal. There's some BOVs out there that are perfectly legal (No wastegate noise) but are made to look like one that does, cops see that and pretty much ignore the other stuff. Other good one is pod filters if your car comes stock with an Intercooler and it's still the 'stock' one that comes out. You'll get told that the Pod filters are illegal, just fire back in that "I'm totally ignorant because it's my first Turbo car" manner that you thought a vehicle was allowed one air-modification (Pod or Intercooler) and since it came standard with the Intercooler, the Pod is the mod (Worked for me on the WRX).
Just my experiences from the past, hope they might help.
^^ hiding a turbo under a skyline engine doesnt quite seem practical to me lol (not taking the piss). just do it right the first time and dont run the risk of being defected. check out the hypergear forum and the results hes getting from his hi-flows. and as far as pods go, just get a hi flow panel filter. people are still using the standard airboxes with hi hp engines. which means you can upgrade your intercooler.
Totally agree with you because,i dont want anything to do with cops. Im trying to get an aftermrket twin turbo at about 15psi.and yes i will change the pistons and crank to forged ones. and do hi flows have similar perfomance to aftermarket comparing apple for apple.
so your looking at a gtr? look at the hypergear thread and ask him a question regarding hi-flowing the gtr turbos (he will need a power figure that you want to achieve). also check out the build threads and see what other people have done, there may not be a need to go fully forged if you only want say 300kws etc. do a bit more homework and choose a power figure you want to achieve before you start spending thousands ;)
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
