Hi all,
Just wondering if anyone can shead any light on my thoughts about upgrading the standard injectores in my 1996 gtst skyline..
i'v been reading a lil on the power ppl are making with mods they hav done to acheive the power.. im after a responsive 250 or so rwkw..
Now i'm thinking i deffinatly have to upgrade the injector's in order to acheive that sort of pwr, yet in sum threads i read from others, they are saying they have, bla, bla, bla, also with an after market fule reg.. and no after market injectores..??
So my question "is it possible to make 250rwkw Safely with a fule reg and no aftermarket injectors" .. ??
Cheers guys..!
https://www.sau.com.au/forums/topic/338553-bigger-injectors/
Hi all,
Cheers guys..!
No
If you wana upgrade your car do it properly or dont do it, think about it not only are you now pushing the car over the standard power but do you really want to be doing that pushing standard parts that far and knowing failure can lead to a engine gone. Just get a set of nismo 555 for that power or if you want to save I guess you could atleast hi flow your stock ones.
Indeed stock 370cc injectors SHOULD make 300rwhp if you have everything "right" (nice tune, good fuel pump, efficient engine setup). But then again, that's not 250rwkw, it's 224rwkw.
Get some bigger injectors. Also, your injectors are getting old now anyway and are probably half full of gunk. Get new ones (or at least cleaned and flow checked S15 445cc ones). Add new o-rings and you will have another 20% head room. I'd suggest 550cc though if you bother. a couple of hundred extra (compared to S15 inj) spent properly now will be worth it in a year or 2
Edited by simpletool
the general rule is that:
< ~230rwkw stock injectors/fuel pump/afm will manage (ecu is still needed for decent power)
> ~230rwkw bigger or highflowed injectors/aftermarket fuel pump/z32afm/ecu are required
knowing what i know now... if i had a fresh gtst, i'd probably buy a second hand gcg highflow, second hand pfc, max out all the stock injectors/afm & throw monies at suspension and handling. more power can always be purchased later if you want/need it
So you would prefer 230rwkw compared to your current 320rwkw? Yeah right :D
if you had the injectors prefessionally cleaned first to make sure they are actually flowing 100%, you could probably nudge 250kw on them without touching fuel pressure too much, but it isn't advisable.
Rolls, he couldn't use GTR injectors as r33 rb25 ones are side feed not top feed like rb26 ones. he could use s15 injectors though.
A custom fuel rail is pretty cheap, that's what I did.
Edited by Rolls
Well guy's appreciated the help!
Yea i think ill just by a second hand set of injectors of sumone that fit straight in and be done with it :down:
i already hav a fmic, full exhaust, pod, gcg hi-flow turbo..
soo i just hav to get the injectores, fule pump, z32 afm, and a re-map and we should be happy :)
Cheers..
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
