Hi
I have been searching for a couple of hours, but don't seem to find anything like the problem I'm having....
Rb25det, 3" turbo back, Apexi filter, Freddy intake, otherwise original.
Doesn't matter hot or cold engine, it takes a few (2-3-4-5) tries to get it to start. This problem only started a couple of weeks ago, earlier it always started first try.
The strange thing is once it's running, it's all smooth, idle and rev, no noticeble problems at all.
Fuelpump is priming, diagnoses gave 55, no visual sparks around coilpacks (tested in total darkness), new temp sensor did nothing.
Plugs bcpr6es-11, fuelpump and fuelfilter is just a couple of months old (and not that many miles on them).
Any advise would be appreciated!
Thanx:-)
https://www.sau.com.au/forums/topic/338554-strange-starting-problems/
Cranking speed appears unchanged, by the sound of it it's all good.
Battery is less than a year old, measured 13.2V (14.1v at idle). Oh, and noise is just your normal noise, engine cranking. No coughing or sputtering.
Edited by 240zrb
No, I haven't got a fuel pressure gauge. But that could be a good point to check. I'll see if I can borrow a gauge.
Still, it pulls strong idle to redline (well, haven't tried redline but up to 5-6000). So, could it be fuel pressure..? pump is walbro, straight wire battery - relay - pump
  • 4 months later...
My gtr has started to do this recently too. After I put in bcpr7es spark plugs it would only do it when u go to restart the car when hot. Plenty of cranking then when it does start revs r very low so u tap the throttle and it picks up and idles perfect.
My cold start was perfect up until yesterday, now that's gone shit too
I thought it might of been those plugs so I put my old iridiums back in but same problem
Cars got sard fuel pump, nismo 600cc injectors, -7 turbos, and nistune...only been road tuned
Any ideas on what it could be??? Driving me nuts !
funny that u guys mention this as i have a similar problem with my r33 gtr.
sum days it starts perfect and other days it wont, have to crank it 2 or 3 times before it wants to start and have to hit the accelerator aswell to get revs up.
is there anyway it could be a starter motor or alternator related problem?
it gives me the shits, ill start it and drive to work then at the eend of the day it sum times doesnt want to start again.
i also changed the battery and that didnt help
I still haven't figured out this, but in my case I have discovered: If I just touch the gas pedal just a tiny tiny bit, and crank, it fires right up:-) So, I haven't tryed too hard finding the real solution to this problem. If I don't put pressure on the pedal it takes x tries to fire it up, and the same happens if I try to pump / half pedal / full pedal...
Thanx for the advice:-)
It idles at about 800 I think (hard to remember, haven't had it running for months)
I'll try checking the TPS, but not for a couple of months... I live in the northern most part of Norway, and it's freaking cold at the moment (well, now it's just -15 celsius, we've had a couple of weeks with -25-30 celsius. But I'm not firing the 25 untill it's + something.
And I need to hook up a diagnose plug, as it was not in the wiring I got with the engine. Engine vent into a 240z and I didn't think I would a plug, but now I need one for the Nistune:-)
Edited by 240zrb
It's just a summer car, as in only out on the streets during summer, but I'll keep your advice in mind:-) Thanx.
A pic if anyone wanna see the old Datsun with the new heart (and some plastic surgery...):
http://forums.hybridz.org/index.php/gallery/image/24342-73-240z-rb25det/
I know its normal for Norway, but I can't get over those -20' temps........I get a -4' frosty morning in winter and swear and curse and vow to move north to a warmer climate.
Well I guess you don't have to worry about +40' days at least.
And apologies for OT.
PS as DVS said your car looks tough :thumbsup:
    • Have a chat with Ben at Moore Performance or Jesse at JS Performance.
    • Thanks both. All good advice. Reminds me of drilling through stone wall for drainage pipe 😬 I'll let you know how I get on if I still have use of my hands afterwards 😅
    • Finally got shipping number for the intake and throttle body, shipped by UPS, so "should" be in my hands sometime next week, fingers fracking crossed
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 🤣, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
