Wrecking S15
Hey guys
Unfortunately, I had a front end accident with my S15. Car is a write off.
It is blue (TV3 in colour), and had 103,xxx kms.
So I am wrecking the car. Here are the parts that I have for sale. If the part you are looking for isn't listed, then it isn't for sale.
Prices are firm, however if you buy several things then we can work something out.
If you don't have the money, don't waste my time. I will NOT be holding any items under any circumstances.
Buyer pays postage.
PM me.
Here goes:
Engine:
S15 SR20DET Engine with loom and standard ECU $3000
- Only ever serviced with Royal Purple XTR racing 10w40 oil every 5,000kms
Includes the following parts:
- Brian Crower Step 2 Cams – Int & exh: 264 duration, 12.06mm lift (3,000kms old)
- Brian Crower Valve Springs (3,000kms old)
- GReddy RAS (3,000kms old)
- Tomei Exhaust Cam Gear (3,000kms old)
One thing, the VTC unit is on its' way out however it still works.
Does not come with turbo or injectors.
ARC Core $400
- Few bent fins
- spray painted matte black for stealth
- was making 248rwkw with this core
Greddy Profec B Spec 2 $300
- in as new condition
- Comes with all wires, hoses etc.
- 2 months old
Stainless Steel intake pipe $180
- suit low mount stock position T28 turbos
Drivetrain:
- S15 Helical Diff in R200 housing with 6 bolt half shafts $200
Suspension/Handling:
- Standard S15 swaybars (front and rear) $50
Brakes:
- 5 Stud conversion with S15 standard brakes setup $700
Including:
- Front and rear calipers
- Front and rear rotors
- Front and rear pads
- Front hubs
- Front and rear knuckles
Rear rotors need to be machined, otherwise they're all good.
Aesthetics/Exterior:
- Nismo Side skirts $250
- TV3 Blue
- Scratches underneath due to lowness
- no cracks
- Plastic, OEM factory option
- JDM S15 tail lights $150
- JDM S15 side mirrors with switch $150
- JDM S15 climate control $120
Interior:
- Factory Odometer with Carbon Fibre Dash with Black rings (103,xxxkms) $100
- S15 front and rear seats $500
- JDM A pillar with boost gauge and sensor $130
- S15 Rear pockets $70 for the pair
- S15 Carpet $120
- S15 boot trim $50
- S15 Upper dash half $200
- S15 Lower dash $150
- S15 Door cards $150 pair (driver and passenger sides)
Last but not least
S15 Rolling shell $1800
- has everything but what is listed above
- front end damage
- PM me for pics
Cheers
Hi can you please PM me your contact number or post a contact/email address and state here?
Or SMS me 0423 850 988
I can't PM until I have 10 posts (which I won't really make here, silvia owner)
I'm keen on the climate control if it includes everything needed to put it in an ADM car. There's a whole bunch of little sensors, along with the plugs/looms, and maybe a motor or two that control the air intakes.
I'm hoping you know what is needed, but if not I can find out and let you know.
Cheers
Edited by uditha01
location?
Melbourne.
Cheers
I have the unit itself out, however I still haven't gotten around to de-looming the car and removing all the plugs, sensors etc. I should be done by tomorrow, if not by the weekend. Either way, I'll let you know.
Cheers
  • 3 weeks later...
 Share
    • So, as it turns out, a new wire was the answer I went for, but getting there was not straightforward... Firstly, I'd been told before by shops that had worked on the car that it had some weird factory wiring, and I can now confirm that is true in at least a couple of places. For example....that very purple/white wire that provides IGN power to ECU pin 31.....I traced it out of the ECU loom into a connector high on the nav's A pillar under the dash, where it headed up and out of site across the dash, then back down at driver's A pillar. After trying about 8 different relays I found it coming into the back of the fuse box, and confirmed it was the same wire with a multimeter* (more to follow on that.... So, which fuse is the ECU IGN power connected to in my car?  Very top right, labelled IGN (good), 10A (good), Auto Trans Control (WTF?). It's not impossible it has been f**ked with before, but if so someone removed the pins from the back of the fuse box and moved it somewhere else, noting an AT control fuse would be functionally useless as the car was auto converted to manual long ago. It is not simply a wire cut and joined to the wrong place, both ends of the wire are the same colour just one is in the wrong location (you can see there is an IGN Engine Control fuse in the bottom row 4th from the right. Note, that is the fuse box sticker from my actual car, so either I have the wrong coin holder sticker, someone f**ked with it post factory, or factory sticker does not match the wiring.....whichever option it is just plain weird. Undermining the likelihood of someone having gone to that trouble to move a power feed when everything else in the loom had already been butchered....the fuse next to it IGN 7.5a ABS doesn't even have a wire running to it....so no idea where that fuse is on this car. All strange. But not the problem with my ECU power.
    • New tank clean paint and install complete 🤙
    • I have heard the frenchys kit (with the smaller toyota compressor) performs fantastic. i havent actually gassed my system yet, so cant confirm myself..
    • https://www.efisolutions.com.au/injector-lower-manifold-collars-adapters-r33-a32-y?gad_source=1&gclid=EAIaIQobChMIjpXb2aLaiAMVYcA8Ah1zkg6JEAQYASABEgJzG_D_BwE
    • correct Ive moved to a r33 oem ball joint - they are actually thicker than alot of the after market and similar
