Hey guys
Unfortunately, I had a front end accident with my S15. Car is a write off.
It is blue (TV3 in colour), and had 103,xxx kms.
So I am wrecking the car. Here are the parts that I have for sale. If the part you are looking for isn't listed, then it isn't for sale.
Prices are firm, however if you buy several things then we can work something out.
If you don't have the money, don't waste my time. I will NOT be holding any items under any circumstances.
Buyer pays postage.
PM me.
Here goes:
Engine:
S15 SR20DET Engine with loom and standard ECU $3000
- Only ever serviced with Royal Purple XTR racing 10w40 oil every 5,000kms
Includes the following parts:
- Brian Crower Step 2 Cams – Int & exh: 264 duration, 12.06mm lift (3,000kms old)
- Brian Crower Valve Springs (3,000kms old)
- GReddy RAS (3,000kms old)
- Tomei Exhaust Cam Gear (3,000kms old)
One thing, the VTC unit is on its' way out however it still works.
Does not come with turbo or injectors.
ARC Core $400
- Few bent fins
- spray painted matte black for stealth
- was making 248rwkw with this core
Greddy Profec B Spec 2 $300
- in as new condition
- Comes with all wires, hoses etc.
- 2 months old
Stainless Steel intake pipe $180
- suit low mount stock position T28 turbos
Drivetrain:
- S15 Helical Diff in R200 housing with 6 bolt half shafts $200
Suspension/Handling:
- Standard S15 swaybars (front and rear) $50
Brakes:
- 5 Stud conversion with S15 standard brakes setup $700
Including:
- Front and rear calipers
- Front and rear rotors
- Front and rear pads
- Front hubs
- Front and rear knuckles
Rear rotors need to be machined, otherwise they're all good.
Aesthetics/Exterior:
- Nismo Side skirts $250
- TV3 Blue
- Scratches underneath due to lowness
- no cracks
- Plastic, OEM factory option
- JDM S15 tail lights $150
- JDM S15 side mirrors with switch $150
- JDM S15 climate control $120
Interior:
- Factory Odometer with Carbon Fibre Dash with Black rings (103,xxxkms) $100
- S15 front and rear seats $500
- JDM A pillar with boost gauge and sensor $130
- S15 Rear pockets $70 for the pair
- S15 Carpet $120
- S15 boot trim $50
- S15 Upper dash half $200
- S15 Lower dash $150
- S15 Door cards $150 pair (driver and passenger sides)
Last but not least
S15 Rolling shell $1800
- has everything but what is listed above
- front end damage
- PM me for pics
Cheers
https://www.sau.com.au/forums/topic/338557-wrecking-s15/
Hi can you please PM me your contact number or post a contact/email address and state here?
Or SMS me 0423 850 988
I can't PM until I have 10 posts (which I won't really make here, silvia owner)
I'm keen on the climate control if it includes everything needed to put it in an ADM car. There's a whole bunch of little sensors, along with the plugs/looms, and maybe a motor or two that control the air intakes.
I'm hoping you know what is needed, but if not I can find out and let you know.
Cheers
Edited by uditha01
https://www.sau.com.au/forums/topic/338557-wrecking-s15/#findComment-5473289
location?
Melbourne.
Cheers
I have the unit itself out, however I still haven't gotten around to de-looming the car and removing all the plugs, sensors etc. I should be done by tomorrow, if not by the weekend. Either way, I'll let you know.
Cheers
https://www.sau.com.au/forums/topic/338557-wrecking-s15/#findComment-5473925
aye mate still after those parts and how much u can post in WA postcode 6149 mate need them asap thx
Check your inbox
got any injectors at a good price? thanx
Sorry mate sold already.
Just what's listed in the first post.
https://www.sau.com.au/forums/topic/338557-wrecking-s15/#findComment-5474495
  • 3 weeks later...
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
