finally got my baby back on the rd...
yeah REAL good on back support... they dont have as much movent like the GTST seats but they dont need em... they like mold to ur back... heaps comfy... a really decent upgrade.
piss easy to put in... maybe 10mins for each seat... just make sure when ur putting any seat in u never tighten the bolts until all bolts are in and remember to put the belt clip back on.... which i forgot after installing the first one... which was a pain the arse to get on when the seat was bolted in :D
for the cost factor id just go GTR.... they look sweet... suit the rest of the interior and bolt str8 in. Aftermarkets cost more and generally dont come with the right rails. Sure they probably offer more support (and are WAY harder to get in and out) but who needs that much more support ALL the time on the rd?
yeah i guess you are right...
i havent done any research yet on the aftermarket items, but i have sat in a few GTR's and seats look and feel quite good...and if they bolt straight in as you say, might be the way to go...
just worried about how they would look with the rest of the sII interior...do they just come in one colour???
Do they offer any more head room? I need seats that sit lower by at least an inch, or 1/2 an inch with a skin head as well.
I dont like the idea of shaving my head!
mine sit pretty low... im 6ft 2-3 and can fit in with a hat on or even a helmet with 2inches of room to the roof... BARE in mind however i dont have a sunroof which means anyone with a sunroof will still have the same issues
lmao no worries.
if u live anywhere near dingley we can meet up tomorow cause ive got to get a few things to clean it up a bit like front tyres and some paint for the wipers and stuff.
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
