after a really good push on the car last night and the massive help from Joe and Mr.fail
THANKS GUYS
so here's the progress so far
after the night before chasing the subframe around the floor for 4 hours and trying to get the bushes out i finnaly rememberd that we have a vice in the unit well 4 of them lol, i shoved it in and got cutting with the hacksaw then a good few smacks with the hammer and bar got them out a treat in less than 10min's (DOH) then came the pain staking job of getting the paint off it :down: until i brought this wire thing for my grinder and the paint flew off so heres the pics now
mr fail him self flatting back the car after masking all the trim
and joe stripped the engine bay for me taking the slaves out and the wireing ready for flatting and painting and took the door off my old car ready to go on the new car as it seems to be better
from this
to this
this is how how my old car looks now :)
so update then
after taking the subframe down to bare metal i laid a good 2 coats of zink primer on to it and let it dry for a few hours then put a good 2 coats of hammerite smooth black on the top half and i think it's came out quite good
so with the paint was drying i proceeded to get the engine and box ready to take out
me and lloyd were pretty fooked working on the cars all day and this was about 7.00 pm
so back to the engine after lloyd and adam gave me a chuck and about 2 hours later
TA dahhhhhhhhh
and this is whats left
more later
i had some solid bushes made up that look like this
then started to build the rear subframe up with all the new arm's and bushes
so then i started on the diff i had a small leak on it so striped the back plate off and cleaned it up and put a new gasket on then gave it a clean then primed it up then hammerited it in smooth black
then made a start on the arches
rubbed them down and then a good coat of white
ok not too much going on really but working on the plenum so here how i have done it
you can see the water feed across the plenum? the holes needed to be drilled out by 2mm as the holes in the plenum didnt line up bang on but this didnt cause any problems at all, also fitted the AAC valve with a new gasket and bolted straight up reall nice
so now the piping and i re-used all the pipe that i already had from the stock plenum any way and the clamps too, use this pipe
and cut this amount of pipe off
then the other end of the pipe you have this
cut this much off ish
but remember mesure twice cut once :down:
then i got some plumbers tape (PTFE) and wraped the outlet threads up like this
and inserted it in to here, 19mm spanner was used but dont go mad thinking it will go all the way in it wont, but a goot 3/4 the way in and nice a tight :)
then the pips that was cut earlier was installed like this
you will also see that there is on pipe lift to fit on the ACC ? you will need to get some pipe to go from there to the inlet pipe from the cooler thet you will need to get made and will be added to the thread at at later date
so on to the injectors pretty much as you took them off BUT replace any worn or old "O" rings and top tip use vasalene (??) or you will tear them and cause fuel leak's, i also needed to open the holes a little on the rail to ease them going in
i managed to buy a Q45 from GARAGE D so i didnt need an adapter plate and loose power with the set up im going for
stock one on the top lol
ENGINE PIPE'S
so down to the engine piping now heres how it looks stock
and took all this off as im going for a spec 1 oil filter housing to reduce piping and the chance of air locks as im running a front mount oil cooler
this is the pipe off the heater pipes that run across the back of the engine, i made a cut here to make it square 90 bend now
and used the supplied joiner here
then used some of the pipe that im using on the AAC to run from the old location of the water pipes and used good clamps and did them up real tight
you can see there is 2 water pipes left to connect ill show you what im doing with those in the next update
thanks for looking Noel@ jpoc.co.uk
what a fantastic weekend!
I DROVE THE CAR OFF THE RAMP'S AND EVEN OUT IN TO THE SUN LIGHT!!!!!!
after Geoff painted the body kit (just waiting for it to dry) and Martin (Teyaki auto's) tracked the car up a treat, then fitted the bonnet catches last night we are sooooooo close now :down: here are some pic's for you to have a nose at
hope to be having it MOT'd and mapped by PROTUNER (greg gush=god) tonight or even tomorrow daytime fit the body kit and off to santa pod Wednesday for a shake down ready for llandow's BDC on saturday
it's pretty easy to be honest, lots of boxes marked up and take lots of pics too so you can go back to them when you need too
while it was all out i did a wire tuck too and took the loom behind the dash then brought what i needed just below the plenum to keep the wires out of the heat
Edited by jpoc_noel
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
