Im ready to get my car tuned, found 4B Action at cardiff nsw who are a nistune agent. Quoted $1100 for them to send ecu to nistune to fit daughter board, and full tune. Is this reasonable? Anyone dealt with them?
I need a bigger fuel pump and injectors. What fuel pump do i need to fit to a s2 neo stagea , where to buy it and how much should i pay?
Ill probably go with seimens 650 cc injectors.
Advice please guys.
Advice please guys.
I have the same car, fitted with nistune.
I recently put the walbro gss342 in mine, fitted straight in. http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=180533428704
They are tricky boards to fit, i had mine done locally but it needs to be done by an expert with the right gear.
A cheaper option may be to send your ecu directly to matt had get him to fit it for you, and then get them to tune it.
That listing doesnt cover the type 4 board, which the OP has. Matt will fit and supply the board. Board is 260, fitting is 60
**EDIT**
Type 4 board, same seller/tuner http://cgi.ebay.com.au/NISTUNE-TYPE-3-4-IN...=item2c56c7df1c
Edited by kjb_r33
$1100 is what a lot of tuners charge. there are some cheaper though. it really comes down to how much you trust the local guy. if you trust him to do a good job then it is worth paying the extra money to get it done locally, that way if something goes wrong you can take it back there easily to get it sorted.
I sold my 300zx to a guy in the hunter, 4B is almost the only one listed in newcastle for tuning the Nistune. I gave the guy their contact details, they tuned his car and he was very happy with it.
By all accounts he was pretty thorough, but i have had no first hand experience with them.
$1100 is about the norm but I'd be making sure you get a Single User license for the Nistune software with that...
Board - ~$260
Fitting - $beer (I have a mate that does the soldering for me)
Single user license - $200
Tuning - $400-500 (~4hrs on dyno @ 100-120/hr)
Total - ~$1000
OR
Buy the board yourself direct from NIStune, find someone to fit it, then just pay the tuners tuning costs.
so it seems fair, the shop is only 2 minutes away so that makes everything simple. when i get the board fitted to my ecu can i drive the car to the shop with bigger injectors and a z32 afm? what impedence injectors do i need?
No, the k multiplier will need to be changed for injectors and the AFM. the standard injectors are standard resistance, the seimens are fine, no resistor needed.
If you have a User license for the software you can go in and use the inbuilt tool to change AFM and injector size, this should get you close enough to drive it to the workshop (just don't boost it up).
you can ask matt from nistune, or whoever is doing your board, to have the board ready for z32 afm, and whatever size injectors you're putting in. then the car will start and run to get you to the dyno.
Edited by Munkyb0y
exactly. you can have them set up the ecu so that you can put the afm and injectors in while the board is being done, then when you get the ecu back, just plug it in and it will drive fine.
I still wouldn't load it right up until it's been tuned though. The inbuilt tool for changing the afm and injectors comes close but odds are things still need to be massaged to be running spot on.
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
