Im ready to get my car tuned, found 4B Action at cardiff nsw who are a nistune agent. Quoted $1100 for them to send ecu to nistune to fit daughter board, and full tune. Is this reasonable? Anyone dealt with them?
I need a bigger fuel pump and injectors. What fuel pump do i need to fit to a s2 neo stagea , where to buy it and how much should i pay?
Ill probably go with seimens 650 cc injectors.
Advice please guys.
Advice please guys.
I have the same car, fitted with nistune.
I recently put the walbro gss342 in mine, fitted straight in. http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=180533428704
They are tricky boards to fit, i had mine done locally but it needs to be done by an expert with the right gear.
A cheaper option may be to send your ecu directly to matt had get him to fit it for you, and then get them to tune it.
That listing doesnt cover the type 4 board, which the OP has. Matt will fit and supply the board. Board is 260, fitting is 60
**EDIT**
Type 4 board, same seller/tuner http://cgi.ebay.com.au/NISTUNE-TYPE-3-4-IN...=item2c56c7df1c
Edited by kjb_r33
$1100 is what a lot of tuners charge. there are some cheaper though. it really comes down to how much you trust the local guy. if you trust him to do a good job then it is worth paying the extra money to get it done locally, that way if something goes wrong you can take it back there easily to get it sorted.
I sold my 300zx to a guy in the hunter, 4B is almost the only one listed in newcastle for tuning the Nistune. I gave the guy their contact details, they tuned his car and he was very happy with it.
By all accounts he was pretty thorough, but i have had no first hand experience with them.
$1100 is about the norm but I'd be making sure you get a Single User license for the Nistune software with that...
Board - ~$260
Fitting - $beer (I have a mate that does the soldering for me)
Single user license - $200
Tuning - $400-500 (~4hrs on dyno @ 100-120/hr)
Total - ~$1000
OR
Buy the board yourself direct from NIStune, find someone to fit it, then just pay the tuners tuning costs.
so it seems fair, the shop is only 2 minutes away so that makes everything simple. when i get the board fitted to my ecu can i drive the car to the shop with bigger injectors and a z32 afm? what impedence injectors do i need?
No, the k multiplier will need to be changed for injectors and the AFM. the standard injectors are standard resistance, the seimens are fine, no resistor needed.
If you have a User license for the software you can go in and use the inbuilt tool to change AFM and injector size, this should get you close enough to drive it to the workshop (just don't boost it up).
you can ask matt from nistune, or whoever is doing your board, to have the board ready for z32 afm, and whatever size injectors you're putting in. then the car will start and run to get you to the dyno.
Edited by Munkyb0y
exactly. you can have them set up the ecu so that you can put the afm and injectors in while the board is being done, then when you get the ecu back, just plug it in and it will drive fine.
I still wouldn't load it right up until it's been tuned though. The inbuilt tool for changing the afm and injectors comes close but odds are things still need to be massaged to be running spot on.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
