Hello everyone,
Im selling due to life throwing a curve ball. I require a new vehicle for an up coming job. I already have one lined up, so NO TRADES.
I have receipts for all purchases, minus items purchase via Private Sale or Forums. But I do have a list of everything purchased+prices.
Contact: 0414 595 397 or PM
Price: $16,500 with RWC
Can and will post more pics on request..........
Note: Plates are not included in the sale.
Currently Street Tuned for economy. Gets 550-600km/Full Tank.
Upon Deposit and agreement, the Buyer may request any further adjustments to the vehicle;
-Ride height
-Re fit Air Box, BOV etc
-I can also organise a complete tune.
Comes with Spares: Air Box, Factory Struts&Springs, Control arms, BOV, Grille
Make: Nissan
Model: Stagea WGC34
Year: Nov 99'
Engine: Neo RB25DET
Drive: AWD Triptonic - SemiAuto
KMs: 88,XXX
Spec: Full Lux RSFOUR
Rego Expires: Jan 11'
This one is FULLY OPTIONED
-Complete DAYZ KIT
-Duel Sun Roof
-Leather Seats
-Heated Seats
-Rear Seats recline
-Plush Floor mats (VERY rare)
-Boot mat (rare)
-Cargo net (rare)
-Stainless 'style' Door sill trim (EXTREMELY Rare)
-Suede Door cards
-Wood Grain 'style' trims/steering wheel/switch surrounds
-FACTORY Xenon headlights - Height/Angle adjustable
-Oil + Filter Serviced EVERY 5,000km
-Coolant flushed + changed approx 15,000km ago
-Brake Fluid flushed + changed approx 15,000km ago
-Brake Rotors + Pads approx 25,000km ago
-Transmission had a service when I had the Shift Kit installed approx 5,000km ago
-BFG Goodrich G-Force Tires approx 10,000km ago
-Wheel balance + rotate approx 20km ago
**Engine:
-NisTune (Type 4 Board)
-Custom Turn Flow Intercooler - (Street legal)
-Black Silicone pieces (for a stealthy look)
-K&N Pod
-Cold Air Induction
-GReddy Profec Bspec Boost Controller
-Full 3" Turbo back Exhaust
-High Flow Cat
-Twin Core Copper Raditator
-NGK Iridium Spark Plugs
-Turbosmart V-Port Bov
-New Cam Cover Seals
-Custom Catch Can
-Custom Stainless Cooler Piping
**Transmission:
-Custom Shift Kit (was serviced at the same time)
-Relocated Trans Cooler
**Brakes/Suspension:
-R34 GTT Front Calipers
-R34 GTT Front Slotted DBA Rotors
-R34 GTT Front HD Bendix pads
-R34 GTT Read Calipers
-R34 GTT Rear Slotted DBA Rotors
-R34 GTT Rear GCT Bendix Pads
-Genuine Japanese Tien Coilovers (Front 6kg/Rear 6kg)
-D-Max Rear Adjustable Camber Arms
-D-max Rear Adjustable Toe Arms
-Whiteline Rear Swaybar (R34 GTR)
-New Front CV Boots (Both Inner and Outers)
**Exterior:
-HIDs (Fog lights)
-Genuine Clear Nismo Side Indicators
-Non-Turbo Grille (Looks VIP)
-17x9+35 Drift Teks - Silver with Machine Lips
**Interior:
-Defi Water Temp Gauge
-Defi Boost Guage
-JVC Head Unit
-14% Tint on front windows + Windscreen Strip
-Red LEDs behind Cluster (everything is RED)
-Bright White LEDs in the Interior Lights
Honestly Just posting to see what happens here,
the look of this car is making me fall in love with C34's again.
I need approval from work to get a Wagon!
I'll help you talk Cazz into it!
Thankyou for the compliments :D
I shall get around the interior pics tomorrow ASAP!!!
I was ment to take some more pics today but the weather was looking abit... Blah!
Stay tuned............................................ :)
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
