  • Replies 50
yeah i noticed the sig. i wonder if rukus has even had work done there? of are you just spruiking for the fun of it?
ye Yavuz has tuned my 33 and 32 and done a full service on it too b4..
Yavuz is also one of my old mates' brother
I have E BOOST II in the my Zed TT slot car and very good. We did have issues with a GTR with Blitz Dual SBCi over 20 psi. It was fluctuating the boost badly and could not stabilise it no matter what we did. We swapped it for another after trying to add filters in line and adjust gain etc thinking it may be faulty and then after changing for another new one same probs. Put E Boost in and all good. Bigger solenoid the Blitz dual solenoid is not very big in fact small and may not cope with big boost it seems. Yes Ben our tuner with 10.66 132mph MR2 is clever and tells it as it is and very capable. We have lap top tuning for Power FC GTR and GTS-T we also specialise in GTR, GTS-T and ZEDs.
ive had my race car tuned r32 gtr form crd and the tune was ok but there was alot of timming in it like 40 deg and i spent $1200 for tune and to move the timming gears then it was tuned at jem (just engine management) by Adam he has a lap top with the soft ware for power fc and most other after market computers when the car was finished it had gained 33 kw at the wheels and drove great at a cost of $350 His address is unit 3/10 Helles Ave Moorebank
    • Cleaner signal so timing is more accurate at all rpm also found it to start more on first rotation but could also be I've nailed prime and crank fuel. For under $400 and 30mins of your time, its a good solution especially once the optical sensor does start to play up you won't notice it until in higher rpm and it heat soaks.
    • On a 400hp RB, what benefits other than "it's not 30+ years old" are you seeing from the NZ Wiring Kit trigger setup? If it were me going to change triggering, my belief would be to go for a crank trigger to remove the issues caused by what people claim is belt stretch etc, but that's from my understanding a much larger issue for super high power, rather than those in the 400hp and below club.
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
