Lap Timing Equipment
Neither do i . I'm using a starlane digi race stealth - something or other . it's funny when you get things like attatched pic:
That's just telling you you can backoff the pace a little bit and still win the race... :P
  • 2 months later...
  • 1 year later...
I use the LT-6000 and really like it. Works as advertised and the data logging is quite good.
Down sides: is only accurate to about +/- 0.2, but honestly not like us club racers are trying to qualify for F1.
Also, the software and interface aren't the easiest to use.
But for $400 and gives you real time lap times in the car plus green/red projected times on your lap your doing, it is a great tool.
Most phones don't have high speed GPS sensors. So to get more acurate you should have a dedicated GPS device capturing at 10 hertz. But phone apps are ok as long as you aren't looking for too much accuracy.
V Box and similar can incorporate video as well as having a whole lot of useful driving and data analysis features. Performance Box is cheaper, not sure what it's features are but it is too big to mount on the steering wheel like the LT-6000 will.
How do users find units like the LT-6000 with a built in GPS in a tin top car? No problem with GPS signal interference requiring a remote mounted sensor?
I mount it on the front window that is what the recommend. Occasionally you'll get a signal wander that causes the location to move about 10m but timing still works fine.
I don't think you'd want it on the steering wheel as that would take your line of sight too far away from the track.
The Dashware software is pre-configured to detect the data file that is made by the Qstarz so you simply import the file into Dashware then drag whatever gauges you want onto your video screen and it works.
Awesome! Is it fussy about what type of video files?
Also, how bright is the screen in the car when it brings up split times etc.? I took my brother's car out to Wakefield yesterday which had an Aim dash, and in the sunlight I couldn't see a thing!
Also, how does it work out where you are on the track when you add the video file? Have you found it to be accurate?
Just can't work out how the video and data logging lines up accurately without any data from the video file.
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
