Neither do i . I'm using a starlane digi race stealth - something or other . it's funny when you get things like attatched pic:
That's just telling you you can backoff the pace a little bit and still win the race... :P
  • 2 months later...
  • 1 year later...
I use the LT-6000 and really like it. Works as advertised and the data logging is quite good.
Down sides: is only accurate to about +/- 0.2, but honestly not like us club racers are trying to qualify for F1.
Also, the software and interface aren't the easiest to use.
But for $400 and gives you real time lap times in the car plus green/red projected times on your lap your doing, it is a great tool.
Most phones don't have high speed GPS sensors. So to get more acurate you should have a dedicated GPS device capturing at 10 hertz. But phone apps are ok as long as you aren't looking for too much accuracy.
Are there any dedicated gps lap timers that take video as well? That's why I like this app, but worried about launching my iPhone out into the back paddock of Wakefield though!
V Box and similar can incorporate video as well as having a whole lot of useful driving and data analysis features. Performance Box is cheaper, not sure what it's features are but it is too big to mount on the steering wheel like the LT-6000 will.
How do users find units like the LT-6000 with a built in GPS in a tin top car? No problem with GPS signal interference requiring a remote mounted sensor?
I mount it on the front window that is what the recommend. Occasionally you'll get a signal wander that causes the location to move about 10m but timing still works fine.
I don't think you'd want it on the steering wheel as that would take your line of sight too far away from the track.
If you mean all the gauges etc then it's just a program that you load the qstarz data file into. Their are dozens of gauge sets available (even clusters from common sports cars) and you can move them around or edit them till your heart is content.
http://www.dashware.net/
The Dashware software is pre-configured to detect the data file that is made by the Qstarz so you simply import the file into Dashware then drag whatever gauges you want onto your video screen and it works.
Awesome! Is it fussy about what type of video files?
Also, how bright is the screen in the car when it brings up split times etc.? I took my brother's car out to Wakefield yesterday which had an Aim dash, and in the sunlight I couldn't see a thing!
Also, how does it work out where you are on the track when you add the video file? Have you found it to be accurate?
Just can't work out how the video and data logging lines up accurately without any data from the video file.
    • As GTS mentioned, it takes a bit of faffing, some fiddling and a little modifying.  With the strainers, you can buy different styles. Some sit flat on the pump, some angle down.  Here are some photos of mine, ignore the ugly welds lol.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
