to OP. cefiro genuine piping fits best. anything else will need slight modification. if you're doing de plus T..
Trust me from experience. Get an r34 smic. Don't sleep eat or piss until you get one. Don't waste time with a31 smic not worth it.
De+t setups run best with r34. It's big but small enough to retain boost response. And to all naysayers. It's plug and play with a31 piping.
Richard, get a core. ive got lots of s13/r32 piping we can make it work dude? if not we can weld them up????
cheers for the replies guys, ive found a cooler but havent bought it yet, if you've got piping and connectors, oooh yea i want them
can we do deals on sunday?
R32 pipes need to be cut down a bit.
I've got a Cefiro SMIC, brackets and pipes which I don't need if I go ahead with buying a halfcut (either tomorrow or Monday).
We can make a deeeaaal yeah ?
Dammit why do you have to be in Perth right now,
from memory R32 SMIC piping dont fit, I was chasing up the piping at one stae and thought to go R32 but the holes through the chassis were in a
O not a O configuration, the piping was quite different.
O O
You'll have a better chance with R33 piping so long as you have the turbo to cooler pipe for the 20 as the 20 turbo has a smaller outlet.
cheers for the info, I got a R32 one and pipes and they seemed to fit up ok, I didn't want a FMIC I will if I upgrade the hairdryer
the reason it would be a good idea (or most people do) get a larger intercooler is because the factory intercooler is very small and suffers from heat soak really bad (it's more like a interwarmer , theres nothing cool going through there after a 20 min drive , especially through summer) which is why people were suggesting to buy a fmic , even a small one :( . try his: get some vacuum line and re route the back window squirter line to the intercooler with a garden spray squirter at the end of it (aim it to spray over the core as much as possible) , next hot day after driving it wherever and getting it up to temp for a good 20 min , hit the sqirter button and see/feel the difference it makes :)
I know it makes a huge difference, I had a doozy on my old RB25 VL commohore, the fmic will find its way onto mine soon, I just needed the car back on the road, its a wonder the humble RB20det, I remember when they used to be the fastest thing ever 10 years back, not so much now, but its better than the DE it had, god im glad thats gone
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
