Hello
I have my first FMIC that I am going to fit onto my car.
I have stock turbo, Twin front pipe, stock cat, 3 in exhaust from cat back, and a pod. I have a RB25 turbo that I have not put on yet.
What other supporting mods should I put on now that I have a FMIC. I will buy a boost controller soon to up the boost.
Help please
Why do I need a computer for this? Why do I need the bigger fuel pump? More fuel?
Standard fuel pumps are known to fail. It's cheap insurance.
If you upgrade to the rb25 turbo, keep the boost low untill you get it on a dyno.
Once you up the boost, you may need some GTR injectors a Z32 AFM and a programable ecu such as a nistune.
Or you can just leave the stock turbo on and enjoy it for what it is.
Cheers
Justin
you dont have to but if you want the most out of it and you want to tune out the throttle response that you loose when you fit the FMIC, the piggyback (or remap) will let you do that. the fuel pump is a good insurance plan as its likely the stock one wont keep up with the required flow rate
Fuel pump is a must, don't want a dying old one to cost you an engine! I'm a fan of 044's mounted in tank and know personally of such a set up supporting over 500rwhp.
When I had my RB20, the stock ECU handled 14psi through the stock turbo and 12psi through the RB25 turbo, after looking at the stock maps they are more tolerant than 33gtst's but not as tolerant as 34gtt's. You're looking at somewhere around 250rwhp untuned and probably a fair bit more after a tune.
NIStune is also (IMO) your best option for management.
yeah i would of got a new fuel pump before i spent money on an intercooler..Fuel pump and a boost T, run it at 10-14psi, whatever works best, would of been more powerful and still responsive..
Edited by Arthur T3
So I need a bigger fuel pump if I up the boost on the stock turbo. A Nistune or piggy back will give me the most out of it.
If I upgrade to a Rb25 turbo than I might have to have bigger injectors and a Z32 afm?
If I only up the boost on the 20 turbo, how much HP can I expect without a tune?
Where can I get a Nistune? I live in Japan but if is easier to order it from Australia, than I will.
Upgrading to an RB25 turbo won't need bigger injectors or afm.
On stock RB20 turbo mine was making ~200rwhp on 14psi untuned.
http://www.nistune.com/ but seeing that you're in Japan there should be a multitude of tuners that can remap the RB20 ECU!
What you mean by that? The r34 stock ecu sucks a fat one when it comes to upping the boost it just dumps tons of fuel in the motor
The TP load limit values in the stock maps have a higher threshold up until about 5000rpm when it tapers down and is similar to R32 and R33. R32 handles more in the mid range than the R33.
If you're reaching the load limit, NIStune it already.
You dont NEED it, but every old car i have ever owned has benefited from a better fuel pump..
Upgrade the fuel pump, there are plenty of drop in options (nismo/sard etc) or even a low km GTR fuel pump.
Put an adjustable fuel pressure regulator on and pump up the base pressure 8-10psi.
Put the rb25 turbo on (as long as it's in good condition).
Add a boost controller.
Replace the stock cat with a 'test' pipe... or bigger cat. Even a good condition GTR cat is good.
Have someone re-flash the stock ecu.... You will soon find out how much boost you can run untill you run out of available fuel delivery (injector duty cycle). For reliability I wouldn't run the rb25 turbo much more than 12psi anyway.
Nistune is a great option, but might be more than you need for simple upgrades. If your planning on more upgrades down the track, then it's perfect.
You'll also find you will need a new clutch.
Edited by XRATED
Can I do the mods and flash the computer later?
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
