Going to get some braided lines made up as a few of mine are corroded and leaking..
Having removed the turbos last night i have a question in regards to the lengths. The water (return i think?) from the split on the block for the rear turbo does a loop before the banjo joint on the turbo and the oil supply for the front turbo does the same.
I assume this is so the pipes are equal lengths due to the different locations the splits are on the block. So on to my question..
Should i get the braided lines made up to the exact same lengths as the standard piping (including the loops) or can i get them made up shorter - not sure if this will effect supply/return to the turbos and possibly cause premature wear?
Anyone who could shed some light would be helpful :(
https://www.sau.com.au/forums/topic/338825-rb26-braided-turbo-lines/
Anyone who could shed some light would be helpful :)
Hey,
I think those loops are to allow movement as the manifolds expand/contract (the pipes are quite stiff).
I replaced mine with braided lines (no looping) when I went to a big single; no problems thus far.
Cheers,
Saliya
I'd urge you to use stock replacment steel lines, not braided. Especially if it's a street car. The braided hose will perish relativly quickly witht he constant heat cycling.
But hey, braided hoses look pretty I guess...
J.
well...... oil cooler lines dont run near the exhaust manifold, turbo lines do
just use that orange stuff with the fibreglass inside it, works wonders for high temp sheilding
they come in different sizes to suit braided turbo lines, breather hosing, wiring looms etc
ive used that stuff on breather hoses that are actually touching exhaust piping, its been about a year and its no where close to burning through
pic:
edit: sorry i just realised your still running your twin setup and i also urge you to run the standard metal lines for more reasons than 1
just make sure you use fresh copper washers, the lines have no kinks or have ever been bent
what i wrote above applys to topmounts but i guess you could put some sheilding on the steel lines too? haha
Edited by snozzle
Oil cooler kits all use braided lines, never thought a braided hose would perish any quicker?
I am more wanting to do this for ease of installation - obviously looks aren't important as you can't see down there once the piping is on!
As was said above, oil cooler lines are not exposed to the same heat/thermal cycling as lines in/on/around exhaust manifolds, dump pipes, exhaust housings etc.
How often do are you planning to remove/install the turbo's???
Measuring and making the hoses will take you hours to do properly... Not to mention the cost.
Also, that orange sheithing is designed as a flame barrier... it's designed to stop a direct flame from penitrating it for a pre-determined amount of time. It dose work to insulate against some heat though.
Cheers
Justin
I used the orange stuff to shield a teflon braided oil feed that ran very close to the exhaust manifold (<5mm clearance) and on the turbo drain covering blue rubber hose. After less than 1000k's I've pulled it all apart and the shielding on the drain looks fine however the hose underneath is charred while the orange stuff has dried out and crumbled on the oil feed with the teflon line also blackened. Don't assume this stuff does anything! Hardline and a good air gap are the way to go.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
