hey guys
im thinking of selling my car, dont really drive it often just sits in the garage.
i bought the car in 2008 of a old lady was pretty much standard sr20 so ive built this car from ground up, the conversion is mod plated so it is legal. motor was built at gavin woods autotech on the gold coast, motor is still fresh.
i love this thing but i just dont drive it enough.
the car won best late model award at stadium drift
featured in fast fours magazine this year
also featured at gold coast autosalon
r33 1997 gtr engine
Greddy 264deg easy cams
Greddy valve springs
hks cam gears
gates timing belt
Trust Metal Head Gasket
trust clear cam gear cover
Tomei oil restrictor
Arias Pistons
Eagle rods
Nismo bearings
billet oil pump
N1 Water Pump
Head fully recon'd and lifters set for the cams
Fully balanced
Block and crank crack tested
Block acid dipped, decked etc
Crank linished
garrett gt3582r
greddy high mount manifold
greddy external wastgate type r
greddy y intake pipe
hks pod filters
greddy Fuel Rail
hks fuel reg
Sard 700cc injectors
Tomei Sump Baffles
apexi power fc d-jetro
superspark coilpacks
custom rwd sump
4 inch dump
trust stainless 80mm cat back exhaust
cooling pro 600x300x100 intercooler
custom 3'' cooler piping
saber alloy radiator
twin 12 inch thermos
alloy polished overflow bottle
turbosmart e boost 2 (40psi)
turbosmart supersonic bov
whiteline sway bars front and back
whiteline strut brace
rear adjustable camber arms
rear adjustable toe arms
racing logic coilovers
rb25det gearbox
exedy button clutch
exedy lightweight flywheel
custom tailshaft
walbro fuel pump
saber guages oil press, oil temp, water temp and boost mounted in the air con vents
battery relocated to the boot
r34 gtr v spec front seats
retrimmed door cards in suede
smoked tailights
nismo smoked side indicators
blits fibreglass adr approved vent bonnet
vertex front bar
vertex rear bar
vertex side skirts
shaved boot lock
flared rear guards
resprayed in r34 gtr nur gold (millennium jade) with gold flake including engine bay
volk gts gunmetal grey 18x9+27 18x10+23
made 408rwhp on 15psi and 450rwhp on 18psi
serious offers only i will only sell it at the right price otherwise im keeping it.
$35000
brad 0421511710 or pm
https://www.sau.com.au/forums/topic/338834-e0i-rb26-powered-s15-2001-rbs15/
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
