Hey guys,
I've searched and searched but can't find any information that tells me exactly what I need to know.
Harmonic balancer on my car has come loose over time therefore destroying the keyway on the crank snout.
As opposed to me ripping engine out and fixing that particular problem, I may as well give her a freshen up while she's out.
I don't want anything wild, a standard rebuild would be perfect for me as my car is daily driven. Eventually down the track I see myself possibly fitting a hi-flow, ecu etc. No wild power though. Id just like that peace of mind knowing that I have an as new motor.
Wreckers quote me 2.5 to 3k in and out for a replacement, im guessing for maybe 1 or 2k more I may as well rebuild my motor and know its new.
I can't get one straight opinion on who to see in Victoria, prices, whats involved etc.
So I ask the guru's here, what am I looking at price wise for a standard rebuild on an RB25DET, drive in drive out.
I ask you guys because I would like opinions on trusted workshops that you would recommend I do this. Do it once, do it proper.
Sorry for the long post but I want as much info as I can get. Read too many horror stories about people getting engines rebuild only to blow up on them 10k later!
Thanks,
Evan
https://www.sau.com.au/forums/topic/338835-engine-rebuild-rb25det/
To start with you will need to source a new crank. The one you have cannot/should not be repaired. If anyone tells you otherwise, then you can automatically slot yourself into the engine failure bracket with the rest of them.
Basically a straight rebuild as a freshen up will cost you about $5k but it really depends on what you are doing. Rings and bearings can just be thrown in without too much cost but to do a thorough freshen up, there is a fair bit more to it.
Ye the new crank cost is going to be the killer part out of all of it really.
Stock (or just replacement pistons) are cheap etc. It'll be mainly eaten up in labour & machining costs along with the crank.
Prices will vary but be expecting around the 5k marker as stated.
A 2nd hand motor could be sourced and installed for half that - So you really have to ask yourself how long you are going to keep the car.
Inside of 5 years, IMO forget it.
Buy a 2nd hand motor. Sell the RB25 head/parts and overall the replacement has cost you 2k.
  • Like 1
some very good information there guys, thanks a lot. Takahashi - they are not far from where I live, have definently heard of them and their good rep. Might pay to just give them a call and ask I suppose.
Nismoid - Your idea is good too, my only problem with it is being able to test the engine before buying it, especially if it's out of the vehicle, can it still be comp. tested?
Without a crank - 4k give/take. With a crank 5k give/take.
Thats in/out and assembly costs. Either way soon as you include a crank its double the cost of a replacement 2nd hand motor... 2x over infact.
So logically speaking even if the first motor is a dud - you would still almost be infront getting a 2nd - 2nd/hand motor.
creatd is too slow. i have been waiting 18 months for them to finish my engine
18months?? wtf are they doing crafting the block by hand???
so 5k in/out...
what about if you stripped all the accessories off and took them in a long motor?
Edited by battery
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
