Ok, you guys have got me. If the whole idea was to make me paranoid, you won. I went over the car with a torch, can't see shit, and don't have a blacklight (as suggested).
WHAAAAT THE HELL DID YOU DO (or didn't, I'm convinced now that you guys haven't done shit to it)
  • Replies 407
Posted Images
Oh Owen.... You'll know about it as soon as it's sunny, which is predicted for Sunday! Be reeeaaalllyyy careful about letting it bake!
It's something so obvious you would of overlooked it :banana:
Can I just give up? Cause if it's sunny either of the next two days I'm fkt. Cause I don't get home till 7.30pm that's not very sporting :D
Eggwhite on the roof?
ah damn, forgot this was on again. would have been nice to enter and at least dream about wining a 5D, lol.
might have a go at brief 5 seeing as its an open brief. would be extremely funny if a Lumix took the winning photo :banana:
Hahaha, it would be funny, but I've already noticed a bunch of images being posted that have been taken from a massive variety of cameras, so who knows?
Nah it's not eggwhite on the roof. Where the fcuk would we pull that from. Matt did lay an egg though.
Have you washed your car lately?
I wasn't being sarcastic, I was giving a hint.
I'm a transformer fiend. Got most g1 in boxes, masterpiece prime and lots more stuff. Have close look ay my car. Even the plates on the car are decepticon related because its evil.:ninja:
You're getting closet to finding out...
Ahh, that's why I haven't found it, that side of my car is next to impossible to get at parked where it is.
I've got Masterpiece Ultra Magnus... lols. Got the G1 boxset when it came out, was $150 now I see it around for $75, bah!
Note to self: inspect decal
Paint ultra magnus.
i want the MP Starscream and Megatron pretty bad but alas, that was about the same time i started saving for house and cutting back on useless awesome junk. (Except old console games ). I got the new release prime and i still have my old prime from back in the day. original and shit :)
yeah i wonder if it's blown out by now. I guessed it would on the way back to the gong :ninja:
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
