hey guys
i've got a r33, 95 and i've had it off the road for while.
i rego'd it today and drove it around for a few hours really smooth everything fine.
Afterwards i decided to try and swap my alarm from active mode (arms itself after 30 secs)
to passive mode (controller arms it only)
now its a really easy job to do you just move a jumper up one space.
though after doing my car won't start now for some reason?!?!
the starter motor still cranks
all electrics work (though the hazards will flash 18 times after trying to start it leading me to think the immobilisers is fkd?)
i unplugged all the alarm, still same response.
is there a easy way to bypass the immobilisers?
oh its a steele mate alarm too ( 2 point alarm with 3 way immobilisers fuel,starter,spark?)
this is what it looks like
thanks in advance
https://www.sau.com.au/forums/topic/338855-steele-mate-alarm-help/
well it isnt the alarm, just try a replacement control unit and still worked fine.
i think my ecu is buggered :D
is there any way to check this? aside from the fact my cd player turns on and off with my indicators?
which has never happened before
you might want to remove this post you have just advertised to every theif and crook who reads this pages what sort of alarm you have on your car not a good idea.
hell in 5 yrs i dont think i have ever posted a pic of my car in fear it might get pinched
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
